It would help a lot to know if 2.79a is going to use Python 3.5 or 3.6. Isn't there someone in Blender Foundation that can answer the questionblibli wrote: Sat Jan 20, 2018 6:01 pm Would it be possible to build both a 3.5 and 3.6 version? I'm pretty sure 2.79a will use latest svn with all deps updated because of the vulnerabilities fuzz/scandal.
Windows: Can't enable addon in latest Blender
Re: Windows: Can't enable addon in latest Blender
jensverwiebe
- Supporting Users
Normally that should not be an issue as long as no newer py exclusive functions are used ( which are not afaik ).
On Linux and macOS i made it so the module pulls the python from Blender itself.
Dunno if thats possible with Windows, someone should take a look.
The trick is to use dynamic_lookup on macOS or same default link behaviour on Linux and not even link pythonlib.
Maybe Win need a flag set for such like macOS does. ( equivalent to: -undefined dynamic_lookup )
More to readup here: https://msdn.microsoft.com/en-us/librar ... s.85).aspx
Jens
Jens
So after asking on IRC, they will decide tomorrow. The rule is to not update libs, but they have to balance it with all the bad publicity they got I guess.Dade wrote: Sat Jan 20, 2018 6:09 pmIt would help a lot to know if 2.79a is going to use Python 3.5 or 3.6. Isn't there someone in Blender Foundation that can answer the questionblibli wrote: Sat Jan 20, 2018 6:01 pm Would it be possible to build both a 3.5 and 3.6 version? I'm pretty sure 2.79a will use latest svn with all deps updated because of the vulnerabilities fuzz/scandal.![]()
It is quite the ABC of software release.blibli wrote: Sun Jan 21, 2018 12:12 pm So after asking on IRC, they will decide tomorrow. The rule is to not update libs,
Because that security-thing I have read aroundblibli wrote: Sun Jan 21, 2018 12:12 pm but they have to balance it with all the bad publicity they got I guess.
How is that done in Linux and MacOS? Is there a call to a function similar to what you've linked for microsoft?jensverwiebe wrote: Sat Jan 20, 2018 8:15 pm On Linux and macOS i made it so the module pulls the python from Blender itself.
My understanding from the cmake files and pyluxcore code is that python lib is never referenced and linked directly, but only through boost.jensverwiebe wrote: Sat Jan 20, 2018 8:15 pm The trick is to use dynamic_lookup on macOS or same default link behaviour on Linux and not even link pythonlib.
Is that correct? Then also boost should not be required to link statically to python?
jensverwiebe
- Supporting Users
Its cause a module "talks" 2-way with a host. But i really dunno anything about win in this regards.acasta69 wrote: Sun Jan 21, 2018 2:51 pmHow is that done in Linux and MacOS? Is there a call to a function similar to what you've linked for microsoft?jensverwiebe wrote: Sat Jan 20, 2018 8:15 pm On Linux and macOS i made it so the module pulls the python from Blender itself.
I doubt you can leave out boost, cause luxcore for sure uses more/other symbols than linked into blender.
Blender relases come with static boost, so only used symbols are to be found ( which explains python works this way )
Jens
Of course, they know it and they are the first wanting 2.79a to be stable to concentrate on 2.8x but...
Yes
This gonna be by far my longest awaiting from a blender official release. i feel so compressed while waiting so ...........................to put my hand on the Engine and shoot a real Q3 track time
jensverwiebe
- Supporting Users
Why waiting ? Grab an actual testbuild, else we don't get rid of hidden bugs.Sharlybg wrote: Mon Jan 22, 2018 6:46 pm This gonna be by far my longest awaiting from a blender official release. i feel so compressed while waiting so ...........................to put my hand on the Engine and shoot a real Q3 track time![]()
Just avoid using such builds as production sw.
Edit: just saw this time we had no testbuilds
Check here: http://download.blender.org/release/Blender2.79/
Jens
I hope so. Also hope that when testbuilds will be there blender will not refuse to install blendluxcore. I've try with this buildsEdit: just saw this time we had no testbuilds, but they should show up asap. Today awaiting an "AHOI".
Jens
( https://builder.blender.org/download/ )
and it return error .
