Mac OS
AndreD
Mac OS
Post by AndreD »
I am just trying the first mac version,
I get this error:
  File "/private/var/folders/qr/g00zj9_91m3_xs4l5c5lvykc0000gn/T/AppTranslocation/93244D79-C0F7-42A3-BE5D-378F82ED9B17/d/blender.app/Contents/Resources/2.79/scripts/modules/addon_utils.py", line 331, in enable
    mod = __import__(module_name)
  File "/Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/__init__.py", line 2, in <module>
    from .bin import pyluxcore
ImportError: dlopen(/Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so, 2): Library not loaded: @rpath/libembree.2.dylib
  Referenced from: /Users/andredupke/Library/Application Support/Blender/2.79/scripts/addons/BlendLuxCore/bin/pyluxcore.so
  Reason: image not found
Re: Mac OS
I have no idea how MacOS works but, from the error message, you seems to miss Embree library (libembree.2.dylib). I checked and it is included in .zip (it is in the bin directory as expected). So it may be issue with Blender/MacOS paths.
I think you should also try to use a daily build of Blender 2.79a as the 2.79 has some known bug.
jensverwiebe
Supporting Users
Re: Mac OS
Post by jensverwiebe »
AndreD wrote: Fri Jan 19, 2018 6:44 pm Hi,
I get this error:
Thats what i immediately thought when seeing the new embree libs come with @rpath id: rpath is a wonky thing on macOS, i made them loader_path now, works more reliable.
Jens
AndreD
Re: Mac OS
Post by AndreD »
Works fine now, thanks for the fast fix! :-)
patro
Re: Mac OS
Post by patro »
hi guys :) where can i get this mac version :?:
Re: Mac OS
patro wrote: Mon Jan 22, 2018 2:03 pm hi guys :) where can i get this mac version :?:
There is an alpha1 available: https://github.com/LuxCoreRender/BlendLuxCore/releases
At the moment, no one has compiled the alpha2.
jensverwiebe
Supporting Users
Re: Mac OS
Compiling an macOS version is not the problem ( did already testwise an alpha2 with fixed embree references ).
But the packaging is unclear to me: linux and win standalone differ, i have no clue whats needed to do networking etc.)
Jens
patrickwalker
Re: Mac OS
Post by patrickwalker »
So, I decided to give a go at compiling lux for macOS 10.13.2.
I copied the git to my HDD but as soon as I tried using cmake, I start having trouble.
The GUI version of cmake (3.10.2) will not allow me to configure. I never used it much in the past, but I knew you could configure it to use Xcode. Problem is when I hit configure:
CMAKE VERSION DETECTED 3.10.2
CMake Error: CMake was unable to find a build program corresponding to "Ninja".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
Configuring incomplete, errors occurred!
So, the GUI is out. Off to Terminal and updated my homebrew cmake to 3.10.2 also. When I run that:
$ cmake .
-- CMAKE VERSION DETECTED 3.10.2
-- Building mode: Release
-- ################ GENERATED XCODE PROJECT INFORMATION ################
-- Detected system-version: unsupported
-- OSX_DEPLOYMENT_TARGET : 10.6
-- CMAKE_XCODE_ATTRIBUTE_ARCHS ( cmake 2.8 or higher method ): $(NATIVE_ARCH_ACTUAL)
-- OSX SDK SETTING : macosxunsupported
-- XCODE_VERSION : 9.2
-- BUILD_TYPE : Release - compile with: make
-- UPDATE_LUXRAYS_IN_MACOS_REPO : ON
-- LUXRAYS_NO_DEFAULT_CONFIG defined - not using default configuration values.
-- Using custom build config: Config_OSX
-- Using OSX Configuration settings
-- OSX_DEPENDENCY_ROOT : /Users/patrickwilliamwalker/Downloads/lux-source/LuxCore/../macos
-- Disabling Embree BVH builder - no custom Embree used
CMake Error at /usr/local/Cellar/cmake/3.10.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:137 (message):
  Could NOT find Threads (missing: Threads_FOUND)
Call Stack (most recent call first):
  /usr/local/Cellar/cmake/3.10.2/share/cmake/Modules/FindPackageHandleStandardArgs.cmake:378 (_FPHSA_FAILURE_MESSAGE)
  /usr/local/Cellar/cmake/3.10.2/share/cmake/Modules/FindThreads.cmake:205 (FIND_PACKAGE_HANDLE_STANDARD_ARGS)
  cmake/Dependencies.cmake:29 (find_package)
  CMakeLists.txt:76 (include)
-- Configuring incomplete, errors occurred!
CMakeError contains:
Determining if the include file pthread.h exists failed with the following output:
Change Dir: /Users/patrickwilliamwalker/Downloads/lux-source/LuxCore/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" "cmTC_b90f9/fast"
/Applications/Xcode.app/Contents/Developer/usr/bin/make -f CMakeFiles/cmTC_b90f9.dir/build.make CMakeFiles/cmTC_b90f9.dir/build
Building C object CMakeFiles/cmTC_b90f9.dir/CheckIncludeFile.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc   -mmacosx-version-min=10.6   -o CMakeFiles/cmTC_b90f9.dir/CheckIncludeFile.c.o   -c /Users/patrickwilliamwalker/Downloads/lux-source/LuxCore/CMakeFiles/CMakeTmp/CheckIncludeFile.c
/Users/patrickwilliamwalker/Downloads/lux-source/LuxCore/CMakeFiles/CMakeTmp/CheckIncludeFile.c:1:10: fatal error: 'pthread.h' file not found
#include <pthread.h>
1 error generated.
make[1]: *** [CMakeFiles/cmTC_b90f9.dir/CheckIncludeFile.c.o] Error 1
make: *** [cmTC_b90f9/fast] Error 2
I looked through to see if anything in homebrew might help but the only pThread items showing up all involve PHP.
This is why I didn't volunteer to handle macOS.
So, I ran a full HDD search and found at least one pthread.h that's being used by UE4 (/Source/ThirdParty/HTML5/emsdk/emscripten/1.35.0/system/include/libc/pthread.h). I took a look at the contents of that header file and saw no comments whatsoever, which means I can play Russian Roulette and throw that into the source tree...
Re: Mac OS
You are using the source from https://github.com/LuxCoreRender/LuxCore, right ?
I ask because I noticed this message:
Or I have forgot to remove this check or you are using the old sources from https://bitbucket.org/luxrender/luxrays :?:
Second, you should probably start from https://bitbucket.org/luxrender/macos
It is the old Lux repository with the libraries used to compile Lux for MacOS. They are not changed so they may be very useful for you.
This http://www.luxrender.net/forum/viewtopi ... =22&t=4624 may help you too. What was called "luxrays" in old Lux is now the LuxCore repository and it is the only thing you need to compile.
patrickwalker
Re: Mac OS
Using the LuxCoreRender git, not the old bitbucket one.
Throwing pthread.h everywhere didn't work either. ;) Not that I expected it too.
