Hey everyone
Had the same problem here, installed the Intel redistributable yesterday, everything was fine after restarting Blender.
This morning I had the same warning message as yours coming back.
I had to repair Intel's redistributable installation to have Luxcore working again.
Hope this helps
I have a problem to install 2.1alpha4
Re: I have a problem to install 2.1alpha4
I sent you a file with my system info. Private message
I'm running out of idea.
The system info reports a Blender "version: 2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10", it may lack the "b" but I don't know if it is supposed to appear there or not. Anyway pyluxcore can be imported in plain v2.79 too (the only problem is that Blender had a catastrophic bug that was than fixed in "b" version).
Can you check if you have the following files in "C:\Users\pechenov\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\bin" ?
This is Blender 2.79b, the version number is misleading.
>>> bpy.app.version_string
'2.79 (sub 0)'
>>> bpy.app.version
(2, 79, 0)
when i run pyluxcoretool.exe i see
I have this error when I run the installation on my Linux desktop
LInux Mint 19 x64
numpy is bundled with Blender, so something is going wrong.
I remember someone having a similar problem.
You could try to rename your Blender addons folder (.config/Blender/2.79/scripts/addons if I'm not mistaken).
Or maybe your Python installation is somehow messed up?
You could also try "pip3 install numpy", but I doubt it will help since Blender shouldn't use the system Python in the first place.
On another computer I do not run luxmark
