I have a problem to install 2.1alpha4
stefdln
Re: I have a problem to install 2.1alpha4
Post by stefdln »
Hey everyone
Had the same problem here, installed the Intel redistributable yesterday, everything was fine after restarting Blender.
This morning I had the same warning message as yours coming back.
I had to repair Intel's redistributable installation to have Luxcore working again.
Hope this helps
BigGoga
Post by BigGoga »
Dade wrote: Tue Oct 23, 2018 11:48 am
BigGoga wrote: Tue Oct 23, 2018 10:53 am When I launch LuxCore UI there is no error.
This mean the problem is python related. Are you sure to use the official Blender 2.79b (Python v3.5) and not a daily build or v2.80 (Python v3.6) ?
I sent you a file with my system info. Private message
BigGoga wrote: Tue Oct 23, 2018 12:34 pm I sent you a file with my system info. Private message
I'm running out of idea.
The system info reports a Blender "version: 2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10", it may lack the "b" but I don't know if it is supposed to appear there or not. Anyway pyluxcore can be imported in plain v2.79 too (the only problem is that Blender had a catastrophic bug that was than fixed in "b" version).
Can you check if you have the following files in "C:\Users\pechenov\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\bin" ?
Dade wrote: Tue Oct 23, 2018 4:01 pm The system info reports a Blender "version: 2.79 (sub 0), branch: master, commit date: 2018-03-22 14:10", it may lack the "b" but I don't know if it is supposed to appear there or not.
This is Blender 2.79b, the version number is misleading.
>>> bpy.app.version_string
'2.79 (sub 0)'
>>> bpy.app.version
(2, 79, 0)
BigGoga
Post by BigGoga »
when i run pyluxcoretool.exe i see
BigGoga
Post by BigGoga »
I have this error when I run the installation on my Linux desktop
LInux Mint 19 x64
numpy is bundled with Blender, so something is going wrong.
I remember someone having a similar problem.
You could try to rename your Blender addons folder (.config/Blender/2.79/scripts/addons if I'm not mistaken).
Or maybe your Python installation is somehow messed up?
You could also try "pip3 install numpy", but I doubt it will help since Blender shouldn't use the system Python in the first place.
BigGoga
Post by BigGoga »
On another computer I do not run luxmark
