I have a problem to install 2.1alpha4
BigGoga
Post by BigGoga »
I can not understand what to do.
Re: I have a problem to install 2.1alpha4
BigGoga wrote: Tue Oct 23, 2018 7:50 am erorr.jpg
Have you installed the libraries listed at the end of the message viewtopic.php?f=9&t=630 ?
NOTE: Thanks to Acasta69 work, this release for Windows is compiled with VisualStudio 2017. You may need to install the VS2017 runtime libraries: https://support.microsoft.com/en-us/hel ... -downloads
NOTE: due to a bug (https://github.com/embree/embree/issues/195) in Embree v3.2.0, you need to install
also the Intel C++ redistributable (https://software.intel.com/sites/defaul ... .3.210.zip) on Windows
BigGoga
Post by BigGoga »
Yes.
I installed these packages.
BigGoga wrote: Tue Oct 23, 2018 9:21 am Yes.
Are you using the OpenCL version ? Is LuxMark working ?
Are you using Blender 2.79b or a different version?
BigGoga
Post by BigGoga »
I'm using version Blender 2.79b from blender.org
BigGoga
Post by BigGoga »
Dade wrote: Tue Oct 23, 2018 9:28 am Are you using the OpenCL version ? Is LuxMark working ?
I tried to install version with OpenCL version and version without OpenCL
Yes. LuxMark is working.
BigGoga wrote: Tue Oct 23, 2018 10:04 am
Ok, you will have to investigate what DLL you are missing. Download the stand alone version from https://github.com/LuxCoreRender/LuxCor ... opencl.zip
Unpack the .zip and run the luxcoreui.exe, you should get an error (post the message here, please).
You can than use a tool named Dependecy Walker to check what DLL you are missing, the procedure is described here: viewtopic.php?f=4&t=640&p=6412&hilit=de ... lker#p6407
BigGoga
Post by BigGoga »
When I launch LuxCore UI there is no error.
after checking "luxcoreui" with dependencywalker
BigGoga wrote: Tue Oct 23, 2018 10:53 am When I launch LuxCore UI there is no error.
This mean the problem is python related. Are you sure to use the official Blender 2.79b (Python v3.5) and not a daily build or v2.80 (Python v3.6) ?
