Hello everybody!
Why is LuxCore so slow. Using it in Blender 2.79b with the latest LuxCore release the render process never comes to an end. I've just started Blender without changing the scene and started the rendering process using LuxCore. I tried the different releases of LuxCore but that never changed the result. Is this a common problem? How can I get better render results or any render result? Are there any suggestions?
I’m using Blender 2.79b (installed today) with the latest LuxCore release on a one-week old computer with an Intel Core I7 v8th Gen and 16GB of RAM, on Windows 10.
Greetings
Chris
LuxCore newer comes to an end rendering a scene
Re: LuxCore newer comes to an end rendering a scene
The default behaviour is to render endlessly, until the user decides that the image is clean enough.
However, you can specify halt conditions, for example a number of samples.
By the way, here is the BlendLuxCore manual: https://wiki.luxcorerender.org/Category:BlendLuxCore
It contains answers to some other questions a beginner might have, but it is also incomplete.
Can we have an idea of the scen you wan to render ? what kind of settings ?
Maybe upload it.
Maybe upload it.
Thanks for your reply
There was no special scene setup, I just used the startup scene, when you start blender. I've nothing changed.
I will post an image result in a few moments
greetings
Chris
greetings
Chris
