Hi
When viewing without the camera I'm getting some strange triangular shaped artifacts (2 views attached: with and without the camera)
Thank you
Artifacts when viewed without camera
Re: Artifacts when viewed without camera
Theses artifact are mostly visible in orthographic view not in perspective view.
True ??
True ??
Yes, that's correct.Theses artifact are mostly visible in orthographic view not in perspective view.
True ??
.........so, is it normal to have artifacts in orthographic view?
Only BYOB can solve it !Racleborg wrote: Mon Oct 15, 2018 6:53 am .........so, is it normal to have artifacts in orthographic view?
I think I might have seen this before.
Could you upload a scene that shows the problem?
I vaguely remember a problem related to having the camera far clipping plane to far (very faaaaaaar)B.Y.O.B. wrote: Mon Oct 15, 2018 9:30 am I think I might have seen this before.
Hi
I've simplified the scene (needed to be smaller to upload) but the issue is still there.
Thanks
Thanks
- Attachments
- artifacts.blend
- (2.08 MiB) Downloaded 190 times
Properties > Scene > Units > Advanced LuxCore Settings >Racleborg wrote: Mon Oct 15, 2018 11:09 am Hi
Thanks
Set Min. Epsilon higher (Default: 0.00001)
ie: set to: 0.0001
