Metropolis SDS problem?
Re: Metropolis SDS problem?
Post by epilectrolytics »
B.Y.O.B. wrote: Thu Oct 11, 2018 10:53 pmDoes the denoiser even work with BidirVM, have you tested it?
Not yet tested, just an assumption (if it doesn't work I'd use Photoshop).
First I'm going to learn about the engines and samplers before moving on to stuff like the denoiser...
But with BiDirVM+random taking hours to converge it's not that useful anyways, rather Path+metropolis which can be openCL accelerated.
Also BiDirVM+metropolis works fine on another file (no runaway brightness there).
I might open a BiDirVM thread to collect experiences there.
Fox
Post by Fox »
Here is what i ended up with at 3300 Passes. It took 20GB to render.
screen.tool.type = IMAGE_VIEW
periodicsave.film.filename = "film.flm"
periodicsave.film.period = 3600
periodicsave.film.outputs.period = 2400
film.safesave = 1
film.outputs.safesave = 1
light.maxdepth = 256
path.maxdepth = 256
sampler.sobol.adaptive.strength = 0.1
sampler.random.adaptive.strength = 0.1
sampler.metropolis.largesteprate = 0.10000000000000001
sampler.metropolis.maxconsecutivereject = 2048
sampler.metropolis.imagemutationrate = 0.10000000000000001
lightstrategy.type = "UNIFORM"
sampler.type = "METROPOLIS"
scene.epsilon.max = 0.10000000149011612
renderengine.type = "BIDIRVMCPU"
bidirvm.lightpath.count = 16000
bidirvm.startradius.scale = 0.00005
bidirvm.alpha = 0.9999
scene.epsilon.min = 9.9999997473787516e-06
film.filter.width = 4
film.height = 1280
film.filter.type = "GAUSSIAN"
film.width = 2048
film.filter.gaussian.alpha = 4
path.forceblackbackground.enable = 0
filesaver.format = "TXT"
filesaver.renderengine.type = "BIDIRVMCPU"
renderengine.seed = 1
batch.haltspp = 0
batch.halttime = 0
batch.haltthreshold.stoprendering.enable = 0
batch.haltthreshold = 0.0001
film.imagepipelines.0.0.type = "NOP"
film.imagepipelines.0.1.type = "TONEMAP_LUXLINEAR"
film.imagepipelines.0.1.fstop = 2.7999999523162842
film.imagepipelines.0.1.exposure = 0.0099999997764825821
film.imagepipelines.0.1.sensitivity = 100
film.imagepipelines.0.2.type = "CAMERA_RESPONSE_FUNC"
film.imagepipelines.0.2.name = "Kodachrome_64CD"
film.imagepipelines.0.3.type = "GAMMA_CORRECTION"
film.imagepipelines.0.3.value = 2.2000000000000002
film.imagepipelines.0.radiancescales.0.enabled = 1
film.imagepipelines.0.radiancescales.0.globalscale = 1.3
film.outputs.0.index = 0
film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
film.outputs.1.type = "RGB"
film.outputs.1.filename = "RGB.exr"
scene.file = "scene.scn"
Fox wrote: Sun Oct 14, 2018 12:16 pm Here is what i ended up with at 3300 Passes. It took 20GB to render.
This looks totally cool!
Somehow you managed to get some fierce aesthetics out of a flawed engine :D
I don't understand all your settings but will have a closer look.
