Moving from classic LuxRender
lighting_freak
Re: Moving from classic LuxRender
Post by lighting_freak »
OK, I did everything from zero.
There is no error anymore, but the render didn`t start at all.
Is it a problem if you run the console and the node is running on same machine?
Console
Console
Node
Node
It seems that the connections works well. Also the job file seems to be fine. Only the network rendering doesn`t start.
P.S. Network rendering is highly un-test.
OK - let`s test it!
BR
Last edited by lighting_freak on Thu Oct 04, 2018 6:32 pm, edited 1 time in total.
OS - Windows 7 X64
CPU - Intel CORE i7
lighting_freak wrote: Thu Oct 04, 2018 6:05 pm Is it a problem if you run the console and the node is running on same machine?
No, it's not a problem.
lighting_freak
It`s still not working.
Well, so we need a new idea!
OS - Windows 7 X64
CPU - Intel CORE i7
acasta69
Post by acasta69 »
No errors or different messages in the netnode console?
acasta69 wrote: Thu Oct 04, 2018 7:41 pm No errors or different messages in the netnode console?
It is a "known" bug, it happens only on Windows (Linux works fine) and it is something I still need to investigate, there is some kind of deadlock, like if some part of the network packet exchange is lost.
acasta69
Post by acasta69 »
Ok, now I have seen the old related thread and issue.
However I can't reproduce it here.
lighting_freak
new day new chance. Today I've started the Console and the Node.
I've been loading the same exported rendering file I've loaded yesterday - and see, it's working.
I don't have any idea what's different, but anyway...
I tried to connect a second machine (node) and it was working perfectly.
Then after some time I tried to stop the job to see the result.
This messages appear in Console's console (sorry for using a screenshot but there is chance to select the text):
Error message
Error message
By the way - whats the idea of continue work after network rendering has been finished?
I saw (and hope) that a *.flm file should be written. Knowing this extension from old lux makes me hoping that tonemapping and lightgroup scaling etc. can be done in a postprocessing step? At the moment I don't see any option to open this file type, neither in luxcoreui nor somehow in blender.
But OK, let's dig into that later step by step.
Thanks so far.
BR
OS - Windows 7 X64
CPU - Intel CORE i7
lighting_freak wrote: Fri Oct 05, 2018 8:51 am Then after some time I tried to stop the job to see the result.
Are you sure you are not mixing different versions like alpha3 and alpha4 ? The error is quite strange.
lighting_freak wrote: Fri Oct 05, 2018 8:51 am By the way - whats the idea of continue work after network rendering has been finished?
Yes, there is a directory with .flm and many other files, if you restart the rendering it will continue because the directory already exist.
lighting_freak wrote: Fri Oct 05, 2018 8:51 am I saw (and hope) that a *.flm file should be written. Knowing this extension from old lux makes me hoping that tonemapping and lightgroup scaling etc. can be done in a postprocessing step?
It is possible but very complicate border line impossible for an end-user. We are currently lacking an application with a GUI to perform the aforementioned operations.
lighting_freak
I checked the versions one more time and they are equal.
Both setup use acasta69´s pyluxcoretool.exe
The only difference is that on the "Console-machine" this is executed from a Standalone download od luxcore (V2.1 lpha4) and on "Node-only machine" it's executed from a blendluxcore setup. In both cases has the origiinal *.exe file been replaced by the new one.
Well, not so many files after stopping the job, propably caused by the error.
rendering folder
rendering folder
What about using the "old" interface?
BR
OS - Windows 7 X64
CPU - Intel CORE i7
lighting_freak wrote: Fri Oct 05, 2018 10:32 am What about using the "old" interface?
It is using the old LuxRender API, not the new LuxCore API.
