Network rendering support
jensverwiebe
Supporting Users
Re: Network rendering support
Post by jensverwiebe »
Sharlybg wrote: Tue Jan 30, 2018 10:18 pm Just forget to ask and propose if possible :
__ i don't know the GUI tools behind blender and old luxrender UI but assume the licence here must bring what we need.
Blender has an completely own gui written with ogl draws ( ghost ) and i fear Qt along with apache might be incompatible.
I may be wrong with the latter.
IMGui might be it as we already use it, have experience with and i saw really complex programs done with it.
Jens
jensverwiebe
Supporting Users
Followup from the alpha3 announce discussion:
This is what i do atm to keep the package small and keep a good overlook ( wip ):
1: have a simplified dir:
( luxcoreui has now an '$ORIGIN/lib' rpath ! , pyluxcorebla.py's are included in /lib )
2: Use one cmd script ( could be a binary as well ) to acces all cmd's ( todo: merger, done ):
#!/bin/bash
sleep 0.2  # just to let the terminal appear and become active
wmctrl -r :ACTIVE: -e 5,0,0,860,440 # set left/top, experimental
function jumpto
    label=$1
    cmd=$(sed -n "/$label:/{:a;n;p;ba};" $0 | grep -v ':$')
    eval "$cmd"
    exit
start=${1:-"start"}
filename=${1:-"filename"}
jumpto $start
start:
pause=0
echo Choose task: [S]ingleConsole \ Net[C]onsole \ Net[N]ode \ [M]erge \( Leave empty to abort \)
read task
case "$task" in
         "") echo "Canceled by user ..."; sleep 1; exit
        S|s) echo "Setup Console"
	action=console
        C|c)  echo "Setup NetConsole"
	action=netconsole
        N|n) echo "Setup NetNode"
	action=netnode
        M|m) echo "Setup Merge"
	action=merge
        *) echo "Invalid choice ..."; sleep 1; jumpto $start
esac
echo Set extra arguments here \(-h shows helpchart\) \( + return \)
read args
if [ $args == "" ]; then
	echo "No arguments"
else
	echo "Arguments: $args"
fi
if [ "$args" == "-h" ]; then
	pause=10
	echo "Holding help-page for $pause seconds"
elif [ "$task" == "m" ]; then
	pause=3
	echo "Holding result-page for $pause seconds"
fi
filename:
if [[ "$task" != "n" && "$args" != "-h" ]]; then
	echo "Drop or type path(s) to file(s)"
	read filepath
	if [ "$filepath" == "" ]
		then echo "Missing file(s), try again ..."; jumpto $filename
	fi
fi
echo Starting $action
gnome-terminal -e '/bin/bash -c "python3 ./lib/pyluxcore'$action'.py '"$args"' '"$filepath"'; sleep '$pause'" '
jumpto $start
Remark: the sleeps are needed to keep the helppage open a while.
This package is much smaller than the orig. alpha3 ( 90mb vs. 220mb uncompressed, 24mb vs. 140mb bz2 compressed )
and does not need any install. I have already some rework in mind, is on todo.
EDIT: did a few optimizations, added merger
Jens
- I have done the first rendering with a AWS EC2 node in the mix. I was using my home i7 3930K+i7 860 and a remote Intel(R) Xeon(R) CPU E5-2666 v3 @ 2.90GHz (I think it has 18 cores/36 threads) with 60GB ram from AWS Frankfurt data center. The network rendering seems to works well even over internet: It was transferring a 1024x1024 film in less than 2 seconds.
The rendering speed of the AWS Xeon isn't very impressive (even if I like to compile LuxCore with a "make -j 36" :D ) however, the point here is that you can literally lunch any number of AWS EC2 instances you want/can pay.
Hi Dade ! do you think we can render Animation now with AWS EC2 and Luxcore now ?
And What the steps if it is possible ?
Sharlybg wrote: Thu Oct 04, 2018 2:45 pm Hi Dade ! do you think we can render Animation now with AWS EC2 and Luxcore now ?
It is possible but renting one or more high end machine on AWS is quite expansive (and complex). AWS is not intended for end-user usage and you need some good know-how to be able to handle VM creation, etc. on your own.
You can find the prices here: https://aws.amazon.com/ec2/pricing/on-demand/
The point would be to use Spot instances instead of normal one (there is a huge discount), however all the management is quite complex (i.e. someone would have to setup a render farm service and than sell the service so the end-user would see only a front-end and not the AWS back-end).
Renderbot ? any possibility to add Luxcore 2.0 support ?
http://renderbot.net/
Sharlybg wrote: Thu Oct 04, 2018 4:13 pm
Yes, but has it been abandoned ?
No but it is only for cycles render.
I really want to try following a steps by steps instructions from you or BYOB to be able to set VM for Luxcore.
I've created my account on AWS. They want me to select an AMI. Going to learn and familliarize a bit with it.
Sharlybg wrote: Fri Oct 05, 2018 12:10 pm I've created my account on AWS. They want me to select an AMI. Going to learn and familliarize a bit with it.
You can use a standard Ubuntu 14.04LTS or 16, install standalone LuxCore and use the command line tools.
i'm already connected to a Window server ( fear a bit about linux , not a great expert of it ). i had follow the instructions on the Website and manage to connect to the remote instance ( the free one t2 micro ). they suggest me to create a second administrator account for backup if error occur , wich i finally get done.
The remote windows desktop is open. now i need to install blender 2.79b and luxcore alpha 4 normally ?
