Thanks everyone for making LuxCoreRender available, and now for MacOS too!
There is no MacOS version directly on the download page, but on Github LuxCore/releases the standalone version is now available
(no BlendLuxCore yet).
I'm boldly assuming it is okay to provide feedback here.
Sadly I'm no coder and not familiar with Unix, Linux, Github and all that stuff
When I extract the folder and open the luxcoreui file in Terminal, an empty render window appears.
There I can click on "Rendering" > "Load" and the standard MacOS file opener appears.
Then I can browse through the example scenes downloaded earlier and open a .cfg file.
To my disappointment then there is always an error message in the terminal instead of the render starting.
Same on HighSierra or with the no-openCL release.
I'm providing a screenshot with my system specs included and some text from terminal.
I understand these are the very early stages and am very hopeful this will be working soon, thanks again!
Last login: Thu Oct 4 15:14:45 on console
Falks-MBPro:~ me$ /Applications/luxcorerender-v2.1alpha4-mac64-opencl/luxcoreui ; exit;
LuxCoreUI v2.1alpha4 (LuxCore demo: http://www.luxcorerender.org)
[LuxCore][372.594] Configuration:
[LuxCore][372.594] film.width = "512"
[LuxCore][372.594] film.height = "512"
[LuxCore][372.594] scene.file = "scenes/cornell/cornell.scn"
[LuxCore][372.594] film.imagepipelines.0.0.type = "GAMMA_CORRECTION"
[LuxCore][372.594] film.imagepipelines.0.0.value = "2.2"
[LuxCore][372.594] film.outputs.2.type = "MATERIAL_ID_COLOR"
[LuxCore][372.594] film.outputs.2.filename = "cornell_MATERIAL_ID_COLOR.png"
[SDL][372.594] Reading scene: scenes/cornell/cornell.scn
RenderConfig loading error:
Unable to open properties file: scenes/cornell/cornell.scn
[LuxCore][405.985] Configuration:
[LuxCore][405.985] renderengine.type = "PATHOCL"
[LuxCore][405.985] opencl.platform.index = "-1"
[LuxCore][405.985] opencl.cpu.use = "0"
[LuxCore][405.985] opencl.gpu.use = "1"
[LuxCore][405.985] opencl.gpu.workgroup.size = "64"
[LuxCore][405.985] scene.epsilon.min = "9.99999971718068536574719e-10"
[LuxCore][405.985] scene.epsilon.max = "0.100000001490116119384766"
[LuxCore][405.985] accelerator.instances.enable = "0"
[LuxCore][405.985] path.maxdepth = "12"
[LuxCore][405.985] film.width = "800"
[LuxCore][405.985] film.height = "800"
[LuxCore][405.985] sampler.type = "SOBOL"
[LuxCore][405.985] film.filter.type = "GAUSSIAN"
[LuxCore][405.985] film.filter.xwidth = "1"
[LuxCore][405.985] film.filter.ywidth = "1"
[LuxCore][405.985] scene.file = "scene.scn"
[LuxCore][405.985] film.imagepipeline.0.type = "TONEMAP_LINEAR"
[LuxCore][405.985] film.imagepipeline.1.type = "GAMMA_CORRECTION"
[LuxCore][405.985] film.imagepipeline.1.value = "2.2"
[LuxCore][405.985] periodicsave.film.outputs.period = "600"
[SDL][405.985] Reading scene: scene.scn
[SDL][405.987] Texture definition: texture-0x7f4e0b479080
[SDL][405.989] Reading texture map: imagemap-00001.exr
Error opening image file : imagemap-00001.exr (error = "imagemap-00001.exr" is not an OpenEXR file)
[LuxCore][451.298] Configuration:
[LuxCore][451.298] sampler.type = "METROPOLIS"
[LuxCore][451.298] renderengine.type = "BIDIRCPU"
[LuxCore][451.298] light.maxdepth = "12"
[LuxCore][451.298] film.width = "1920"
[LuxCore][451.298] filesaver.renderengine.type = "BIDIRCPU"
[LuxCore][451.298] film.height = "1080"
[LuxCore][451.298] path.maxdepth = "12"
[LuxCore][451.298] film.imagepipeline.0.type = "TONEMAP_AUTOLINEAR"
[LuxCore][451.298] film.imagepipeline.1.type = "GAMMA_CORRECTION"
[LuxCore][451.298] film.imagepipeline.1.value = "2.2"
[LuxCore][451.298] film.outputs.1.filename = "image.png"
[LuxCore][451.298] film.outputs.1.type = "RGB_IMAGEPIPELINE"
[LuxCore][451.298] scene.file = "scene.scn"
[LuxCore][451.298] periodicsave.film.outputs.period = "600"
[SDL][451.298] Reading scene: scene.scn
[SDL][451.300] Texture definition: Imagemap__001_sdklfjsdklf_tex
[SDL][451.300] Reading texture map: imagemap-00000.png
Error opening image file : imagemap-00000.png (error = File failed PNG signature check)
