Dez! wrote: ↑Fri Sep 28, 2018 5:29 am
replaced 1 material. but the essence is in kills gloss.
Might be this bug: viewtopic.php?f=4&t=385
But the bug was present in alpha3 as well, not sure why it should show up when updating to alpha4.
Can you try alpha4 on the exact same scene as alpha3, without the one replaced material?
If the file renders correctly in alpha3, you could downgrade to alpha3 for this project.
I replaced the material in alpha 3 and rendered with the denoiser and everything was excellent. I did not have a saved picture with this new material, to give an example and a comparison.
It's not a new material.
When I made the downgrade through the addon settings from alpha 4 to alpha 3, then the denozer tab completely disappeared.
For this reason I went to the site and downloaded the archive and installed it again. But this time the denoiser worked like this badly.
Yes, I remember the error, and that there are plans to fix it. I do not know why in my scene the denozer worked correctly. Without a denoiser, I can not make a video. I would not have undertaken ..
Okay. I realized that no one knows the answer.
Linux Plasma | Ryzen 5, 32Gb, SSD M2, GT 590 RX | BenQ 27 | Wacom One | Microsoft Ergo | Tie Guan Yin tea http://dezigner.tilda.ws/
Doesn't make very much sense, if alpha3 was working before, it should work now too. Anyway if you post a test scene with an example of the problem, I can try to check what is going on.
