Build LuxCore with Python version 3.6
DorPrz
Post by DorPrz »
Hello all,
I followed this guide:
https://github.com/LuxCoreRender/WindowsCompile
And I want to build with python version 3.6 (I also have blender version with 3.6 python https://github.com/TylerGubala/blenderpy)
What should I change to make it work?
acasta69
Re: Build LuxCore with Python version 3.6
Post by acasta69 »
You can build luxcore with Python 3.6 with this command:
cmake-build-x64.bat /python36
I have tested the resulting pyluxcore with a blender buildbot build, I assume you are using one of those...
DorPrz
Post by DorPrz »
That worked, but now I understand that I wanted to build it as a addon for blender (blendluxcore?) Can it be done?
Clone BlendLuxCore repo, then run get_binaries.py.
See the readme here for more information:
https://github.com/LuxCoreRender/BlendL ... master/bin
After that, you can copy or symlink the BlendLuxCore repo to your Blender addons directory (or zip it and install via user preferences).
DorPrz
Post by DorPrz »
pyluxcoretool.exe is missing, what could be the problem?
DorPrz wrote: Mon Sep 17, 2018 2:03 pm pyluxcoretool.exe is missing, what could be the problem?
Missing PyInstaller when building LuxCore :?:
DorPrz
Post by DorPrz »
Dade wrote: Mon Sep 17, 2018 2:39 pm
Hoped it was it but no, pyinstaller is installed and working:
The build had some warnings I don't know if they are related
Could I generate it manually perhaps? What is the pyinstaller command?
Maybe you are missing PySide?
Anyway, BlendLuxCore works without pyluxcoretools as well, they are only needed for network rendering.
acasta69
Post by acasta69 »
If you need pyluxcoretools.exe, you can generate it after the build is completed with this command:
create-standalone.bat
You will then find a folder named "luxcorerender" containing all required files, including that one.
mib2berlin
Post by mib2berlin »
Hi, if I understand this correctly Blender dev´s upgrade to Python 3.7.
Because you´re at it may change to 3.7 too.
Cheers, mib
https://developer.blender.org/rB51ac494 ... 61d6ba3ad9
