I don't know what is the Luxcore nodes technical limitations but Is it possible for example to do something similar to Node Wrangler http://gregzaal.github.io/node-wrangler/ or Cycles Frame Node https://docs.blender.org/manual/nb/dev/ ... frame.html
LuxCoreRender - Nodes
Re: LuxCoreRender - Nodes
Frames work just like in Cycles: select a few nodes and press Ctrl+J.
I have also thought about implementing some node wrangler features in our node editor.
Which features do you need the most?
This is awesome that this feature exist in Luxcore but at the same time embarrassing how did i missed that shortcut option!B.Y.O.B. wrote: Mon Sep 17, 2018 7:55 am Frames work just like in Cycles: select a few nodes and press Ctrl+J.
Top 2 features from Node Wrangler in my opinion!
1) (Ctrl+Shift+Lmb) Once you try to connect using this shortcut you never want drag nudels manually anymore.
2) (Alt+Rmb) This makes mixing very easy and fast.
Is it possible to make a node groups like in cycles?
https://docs.blender.org/manual/en/dev/ ... roups.html
Not yet, it is on the to do list: https://github.com/LuxCoreRender/BlendL ... issues/127
