Luxcore 2.1 Benchmark
Re: Luxcore 2.1 Benchmark
Just tested hybrid mode gtx 1070 ti + i7 5820k 12 threads and the time is 8 min 13 sec (under linux).
I guess those opencl shading issues are simply unavoidable...
Noticed, but not getting this geo. issue anymore - removed Edge split modifier and used setting under Normals instead.lacilaci wrote: Tue Sep 11, 2018 2:34 pm I guess those opencl shading issues are simply unavoidable...
Also disabled: all tonemapping stuff, Lux postFX, clamping & had set Sun/Sky to it's natural/physical settings.
Got faster rendering & unbiased results...
Here's a BW crop of that area @ 500% and contrast enhanced
yeah also the issue is not appearing on cpu only rendering. Similar to how the edge darkening don't show on bidir.
long triangles/polygons, rough reflections and bad denoiser really are a pain...
The textures don't work for me.
The same on two different pcs, one with Ubuntu and the other with Win10.
I didn't modify anything, I use BlendLuxCore 2.1 alpha3 WITHOUT OpenCL.
Me too. I can't see any textures both for rendering
Any error messages in the console? Or warnings in the error log?
I have on every material this error
Material "corps beige.001": 'bpy_prop_collection[key]: key "Gamma" not found'
Ah, thanks, now I know what caused the error: I saved the scene with my latest dev version of BlendLuxCore, not with v2.1alpha3. There was a change in the imagemap node which causes this error.
I will upload a fixed version, sorry guys.
I uploaded the fixed file. Please test if it works now.
