Instanced object motion blur
Egert_Kanep
Post by Egert_Kanep »
I tried to use animation nodes to convert my particle system to animated meshes and then render them with motion blur, but it didn't work. So I thought maybe it has something to do with object instances. It seems, that instanced objects do not work with motion blur as expected. My animation was a z axis transform, but now right cube has funky motion blur, whereas the left one doesn't seem to have any motion blur to it.
Re: Instanced object motion blur
Does Cycles show the same or a different behaviour?
If you post the scene I can check it.
Did hit a similar issue while doing RBD sim, but after i cached or baked it, it rendered as it should.
Egert_Kanep
Did a test file with Cycles and LuxCore. Cycles is rendering as would be expected of this movement.
I added to blend files with test scenes, they should be produce same results.
mb_cycles.blend
(509.13 KiB) Downloaded 196 times
mb_luxcore.blend
(528.98 KiB) Downloaded 201 times
cycles render
cycles render
luxcorerender
luxcorerender
I have fixed this bug.
