Here are some final pick ! Pathocl sobol + log power +DOF . Rendered on R9 390 + 7970 + i7 8700k . render time from 1hr to 1hr30mn.
							Interior San Pedro Project
Re: Interior San Pedro Project
Outstanding work like always, but I have the feeling something is wrong with the left side of the door in this picture: download/file.php?id=1796&mode=view
Thanks you B.Y.O.B. now that you show me think it too. Will change it for the Door in the right. the original one was for the client dimension. BTW i decide to make the main view a bit contrasted.B.Y.O.B. wrote: Sat Aug 18, 2018 4:45 pm Outstanding work like always, but I have the feeling something is wrong with the left side of the door in this picture: download/file.php?id=1796&mode=view
I think you could put the focus much more on the lamp in the middle.
The bright ceiling light, window on the right and the sofa in the lower right all steal away the focus.
Maybe consider it as a separate lighting setup.
I made a quick, shitty overpaint:
Everything around the reading corner in the middle is darker, the corners of the room are more blueish.
The light in the center is brighter and more yellowish, so you have the typical yellow-blue contrast for a comfortable atmosphere.
It's a bit exaggerated here.
- FarbigeWelt
- Contact:
Terrific work! I like these pictures. How much time do you spend to set up scences like that?Sharlybg wrote: Sat Aug 18, 2018 4:01 pm Here are some final pick ! Pathocl sobol + log power +DOF . Rendered on R9 390 + 7970 + i7 8700k . render time from 1hr to 1hr30mn.
I refrain from criticism.
Yours works has kept me from leaving in Cinema 4D + Corona.
Thanks you all. I'm glad theses render inspire you. The more i work with this engine more become possible.
3 days for design and modelling. One day for render and render correction.
						I've a Bedroom design to finish also for the same customer so could try it there. Why not in a night render.think you could put the focus much more on the lamp in the middle.
Under deadline and only the possibility to work on it at home by night.How much time do you spend to set up scences like that?
- FarbigeWelt
- Contact:
Thank you for sharing time requirement. I think you are pretty fast considering all the details and perfections in your pictures.
