BlendLuxCore Development
- FarbigeWelt
- Contact:
Image Sequence Support continued
After creating the new image sequence you can use Blender Sequencer to export the final movie.
There are lost of possibilities, I focused here on the minimun of steps.
Change view to sequencer and add your files. Select your image sequence with i.e. box selection tool (press b). Change ouput file format to a movie file type you prefer.
(Could be an advantage to enter a name.) And there you have it, your movie with just a few clicks. https://youtu.be/fMdy87gDZiI
MacBook Air with M1
MacBook Air with M1
Re: BlendLuxCore Development
Thanks for testing with the bouncing trees.
Didn't expect you to make a tutorial out of it
- FarbigeWelt
- Contact:
Thank you very much.B.Y.O.B. wrote: Fri Aug 17, 2018 6:09 pm Thanks for testing with the bouncing trees.
Didn't expect you to make a tutorial out of it![]()
One thing to add:
After your movie is exported, erase the strip in the sequencer (select strip, press x and confirm).
MacBook Air with M1
MacBook Air with M1
New quality-of-life features for the viewport: pixel size and the option to disable resolution reduction during first sample.
https://youtu.be/rQl-1213gtE
YEEEEEESSSSS ! we get it well done. Thanks You.B.Y.O.B. wrote: Sat Aug 18, 2018 9:35 am New quality-of-life features for the viewport: pixel size and the option to disable resolution reduction during first sample.
- FarbigeWelt
- Contact:
Great! This is really very appreciated.B.Y.O.B. wrote: Sat Aug 18, 2018 9:35 am New quality-of-life features for the viewport: pixel size and the option to disable resolution reduction during first sample.
Two things might be missing for the top shot: BiDir in view port (I don't now how to change the phyton script to enable BiDir), very useful in my in opinion, and if view port is set to camera zooming may lead to memory issues. You know, the mouse wheel zooms in very fast. Zooming is now issue for top, front, side view.
MacBook Air with M1
MacBook Air with M1
I will consider it, but it is really only useful in corner cases.FarbigeWelt wrote: Sat Aug 18, 2018 12:46 pm BiDir in view port (I don't now how to change the phyton script to enable BiDir), very useful in my in opinion
You mean the issue that the border in camera view is not clamped if it reaches over the viewport area.FarbigeWelt wrote: Sat Aug 18, 2018 12:46 pm if view port is set to camera zooming may lead to memory issues. You know, the mouse wheel zooms in very fast.
Actually, funny story: Originally I wanted to solve this problem yesterday evening. I had attempted to fix it in the past a few times, and this time was no exception: it proved to be such an annoying problem and so difficult to fix that I gave up again. But while working on it I realized that it would be pretty easy to support pixel scaling, so I did that instead.
- FarbigeWelt
- Contact:
Well, there are hobbies like driving a toxic green motor bike or diving in blue skies or riding down an insane steep hill. What is a physical light simulator without the thrill of a real time viewed laser beam cutting through scattering volumes and dispersive materials?B.Y.O.B. wrote: Sat Aug 18, 2018 1:08 pmI will consider it, but it is really only useful in corner cases.FarbigeWelt wrote: Sat Aug 18, 2018 12:46 pm BiDir in view port (I don't now how to change the phyton script to enable BiDir), very useful in my in opinionYou mean the issue that the border in camera view is not clamped if it reaches over the viewport area.FarbigeWelt wrote: Sat Aug 18, 2018 12:46 pm if view port is set to camera zooming may lead to memory issues. You know, the mouse wheel zooms in very fast.
I disagree, this is a real show case, an eye catcher, this is surfing electromagnetic waves at high tide. You've already succeded to balance on the board. You are close to start the fun, aren't you?
This is strange. I did not expect to much difficulties there, actually there should not be any unknown parameter. I hope you find a solution there.
MacBook Air with M1
MacBook Air with M1
I know it sounds stupid, but this is really much harder than it seems. I have the feeling that our code is a bit overcomplicated here, but on the other hand you have tons of stuff to consider. Calculating the viewport camera zoom alone requires arcane equations ...FarbigeWelt wrote: Sat Aug 18, 2018 9:55 pm This is strange. I did not expect to much difficulties there, actually there should not be any unknown parameter. I hope you find a solution there.
Maybe some day I will look at it and see immediately what I was missing in the past.
- FarbigeWelt
- Contact:
Somehow I did expect this.B.Y.O.B. wrote: Sat Aug 18, 2018 10:08 pm Calculating the viewport camera zoom alone requires arcane equations ...
But the fact that zooming changes the view port rectangle size and also respects the check mark in dimensions for border lets me assume view port rectangle size is known in size and position on its displaying window. If rectangle is out of window border this shold be a comparable situation to dimensions border checkmark. How ever, I think you are closer than you see at the moment. Therefore, someday you will see it immediately. I'm sure.
MacBook Air with M1
MacBook Air with M1
