Solar panel
Egert_Kanep
Solar panel
Post by Egert_Kanep »
Made a solar panel material in Substance designer and rendered in LuxCore.
Re: Solar panel
Post by FarbigeWelt »
Nice render!
How to you export to luxcore for rendering? Substance Designer does not mention it.
Egert_Kanep
Re: Solar panel
FarbigeWelt wrote: Thu Aug 16, 2018 6:46 am How to you export to luxcore for rendering? Substance Designer does not mention it.
I just used default metal/rough.
Discovered, that in my first render there was a problem with metal mixing so I fixed it now :D.
Re: Solar panel
Looks even better.
This means, you create tiling textures first, and import them to blender adding then materials in luxcore addon?
Do you know other tiling texture creating software?
Egert_Kanep
Re: Solar panel
FarbigeWelt wrote: Fri Aug 17, 2018 6:17 am This means, you create tiling textures first, and import them to blender adding then materials in luxcore addon?
Yes, I first create a tiling texture and then apply it to my objects. If you're interested in a simpler solution for making tiling textures check out allegorithmic's bitmap2material. But you could just do it manually in Krita.
Re: Solar panel
Egert_Kanep wrote: Fri Aug 17, 2018 8:52 am
Thank you for the hint, looks like Wrap-around mode is exactly what I was looking for.
