Solar panel
- Egert_Kanep
- FarbigeWelt
- Contact:
Re: Solar panel
Nice render!
How to you export to luxcore for rendering? Substance Designer does not mention it.
- Egert_Kanep
Re: Solar panel
I just used default metal/rough.FarbigeWelt wrote: Thu Aug 16, 2018 6:46 am How to you export to luxcore for rendering? Substance Designer does not mention it.
Discovered, that in my first render there was a problem with metal mixing so I fixed it now
- FarbigeWelt
- Contact:
Re: Solar panel
Looks even better.
This means, you create tiling textures first, and import them to blender adding then materials in luxcore addon?
Do you know other tiling texture creating software?
- Egert_Kanep
Re: Solar panel
Yes, I first create a tiling texture and then apply it to my objects. If you're interested in a simpler solution for making tiling textures check out allegorithmic's bitmap2material. But you could just do it manually in Krita.FarbigeWelt wrote: Fri Aug 17, 2018 6:17 am This means, you create tiling textures first, and import them to blender adding then materials in luxcore addon?
- FarbigeWelt
- Contact:
Re: Solar panel
Thank you for the hint, looks like Wrap-around mode is exactly what I was looking for.
