I also do not like how the denoiser works. I do not use it. It distorts the brightness. And sometimes it does not work at all.
In Gimp G'Mic there is a filter that suits me.
destructive denoiser
Re: destructive denoiser
- FarbigeWelt
- Contact:
Isn‘t it a question of the right balance in a picture? If I think about colors and brightness I get several conclusions and one of them tells me a bunch of equotions. Since photosensitive silver plates it has been a quest for the perfect lightening. Don‘t sit in the sun for a candle light dinner. However, noise is a lack of information. In the dark parts there are rays missing and in the brightest parts the sensor gets over saturated if its real it influences neighbourrd sensors, electrons pass the wrong way. I wonder if the math behind rendering has to deal with gap-functions like tangens, or digital precision issues leading to flickers.
MacBook Air with M1
MacBook Air with M1
On another note, if we will get indirect light caching.
Complex areas in shadows would be possibly resolving "almost" just as fast as directly lit areas and denoiser can become pretty helpful even in current state.
In the mean time, is there a way to force luxrender to spend more resources on rendering darker areas of the image?
Adaptivity does help to a certain extent but at one point areas in shadows seem to almost stop progressing.
- FarbigeWelt
- Contact:
Just a guess: random sampler with adaptive set to zero and maybe uniform light strategy.
There are different kind of random pattern, real random does not care about human favour for order. Real random can lead to clumpy noises, but human expect well distributed patterns. A well distributed pattern may help to get smoother areas. Have to look for the article I once read.
MacBook Air with M1
MacBook Air with M1
Thanks for the tip. But it doesn't help. some areas in shadow never resolve and roughly after 4500 samples no visible progress was made.FarbigeWelt wrote: ↑Wed Aug 15, 2018 1:23 pm Just a guess: random sampler with adaptive set to zero and maybe uniform light strategy.
For now only clamping helps.
can i see your denoiser settings ?
Try theses one :
HDT >>>> 0.7
SW >>>>> 8
Scales >>> 4
PR >>>>>> 1
Thanks for the tip. You know, the more I play with it the more I think it's not that much of a denoiser problem.
I think I got way to used to sec. GI engines like light cache of vray or uhd cache of corona.
So now I just don't get it that the shadow areas are pain to resolve
Cycles seem to be somehow worse at denoising but at the same time better at detail preservation, but I can at least cheat there and boost shadows with AO (it's a terrible cheat but at leas some help and it can sorta act as an in-render shadow filler)
Luxcore seem to be powerful yet simple enough to use, but there is still a lot missing and I think I'll give myself a break from it until there is at least "light cache part II" available. I bet 2.1 or 2.2 will be amazing.
