hide world HDRI
hide world HDRI
If I simply use a world HDRI as lighting, is there a way to not have it as the background? I would just like the object, on a solid white or black background, but using the HDRI lighting.
Re: hide world HDRI
This, and additionally you can set the ground material to be a shadow catcher (in the material output node settings) if you want a transparent ground plane with non-transparent shadows. But this is optional, not sure if you need it.Dade wrote: Mon Jul 09, 2018 9:06 pm It should be possible to use the Alpha channel to mask the background
