Test scences GPU Path vs CPU BiDir
FarbigeWelt wrote: Sun Jul 08, 2018 10:02 am Sometimes it is not clear to me what is meant to exterior or interior, e.g. for a plane a 2D object with no volume.
Exterior is where the normal points, interior is the opposite side of the face.
Re: Strange effect using volume, CPU BiDir
You can not use a 2D object if you want a correct volume rendering, just use a slim box if you need a plane.
Two Wine Glasses
Post by FarbigeWelt »
Seems to be close to be finished now. Glass feeds are a bit too clear due to position of the lights I guess.
The idea of the unperfect glasses fits but the effect should be smoother.
Two Wine Glasses
Two Wine Glasses
Cheers! 8-)
MacBook Air with M1
For better results try to follow a real photography as reference both for lighting and compositing !
@Sharlybg
"for lighting" This is a good idea. Thanks.
"and compositing" This only helps of course if the chosen photography has a good composition.
Maybe I should note my intentions for a test scenes in future. Here I liked to show specular lights on glasses what required a little trick for the material.
MacBook Air with M1
Two Wine Glasses
The glasss material here is mixed with metal. The metal supports reflections. To avoid intransparency opacity for metal is set below 1.
Two Wine Glasses on a checkered Table
MacBook Air with M1
Unexpected Wave Front
My intention here is to get a feeling what is possible with volume rendering. Playing around with the nice possibilites of luxcorerender I noticed some unexpected effect. Do you see what I mean?
Strange Waves
Strange Waves
MacBook Air with M1
Ususally hidden Space Property
Further experiments revealed a ususally hidden space property. As it looks like space is made from subcubes and between them there is unexpected space for light extension. Please have a look at the following picture.
Space made from Subcubes
MacBook Air with M1
wasd
Re: Ususally hidden Space Property
Post by wasd »
FarbigeWelt wrote: Wed Jul 11, 2018 5:33 am Further experiments revealed a ususally hidden space property. As it looks like space is made from subcubes and between them there is unexpected space for light extension. Please have a look at the following picture.
Can you upload the scene?
Scene: Ususally hidden Space Property
Yes, here it is.
Volume Waves.zip
Volume Waves
(129.55 KiB) Downloaded 352 times
MacBook Air with M1
