Direct Light cache: hit rate not good
Re: Direct Light cache: hit rate not good
always with 1 sampling path?
So, I open the scene I shared, enable sun&sky and and stop?
Yes but with the fix to the number of light sourcesmarcatore wrote: Thu Jul 05, 2018 7:38 am always with 1 sampling path?
I'm currently rendering it with sun+sky and 5 diffuse/glossy/spec/total path depth.
edit: here it is.
edit: here it is.
Here we are
This is with sun enabled 2min22sec (total time) This is with double resolution (actually my daily output resolution) 33min total time ( total depth 8, diffuse&glossy&specular 4) This is the denoised image I'd like to save the lightcache solution, load it and render this scene with GPU....
In any case a great improvement for this kind of scenarios.
Great job
edit: I didn't understand how to denoise the image with different settings after the render is finished. The "run denoiser" button is always grey (disabled)
Great job
Denoising after the render is finished is not possible.marcatore wrote: Thu Jul 05, 2018 7:54 am edit: I didn't understand how to denoise the image with different settings after the render is finished. The "run denoiser" button is always grey (disabled)
I'd like to say "currently" but I fear it is not really solvable because of Blender API limitations (see https://github.com/LuxCoreRender/BlendL ... -398390095)
So, if I'd like to test different settings, what should be the workflow?
Something like:
- launch render
- when I'm quite satisfied of the sampling, I press Pause of the render
- then in the image editor I change the denoiser settings
is it correct?
Something like:
- launch render
is it correct?
It works quite well, good.
I'm going to add the option to have persistent light cache, saved on file: for camera-only animations it will be possible to use the same cache for all frames. OpenCL support will be the next step once things are settle down.marcatore wrote: Thu Jul 05, 2018 7:54 am I'd like to save the lightcache solution, load it and render this scene with GPU....![]()
Yes.marcatore wrote: Thu Jul 05, 2018 8:27 am Something like:
- launch render
is it correct?
