Direct Light cache: hit rate not good
Re: Direct Light cache: hit rate not good
Can you redo test with the sun enabled ? I'm curious of the outcome.
marcatore
Post by marcatore »
always with 1 sampling path?
So, I open the scene I shared, enable sun&sky and and stop?
marcatore wrote: Thu Jul 05, 2018 7:38 am always with 1 sampling path?
Yes but with the fix to the number of light sources :mrgreen:
I'm currently rendering it with sun+sky and 5 diffuse/glossy/spec/total path depth.
edit: here it is.
marcatore
Post by marcatore »
Dade wrote: Thu Jul 05, 2018 7:40 am
I'm already using the default value :)
marcatore
Post by marcatore »
Here we are
This is with sun enabled 2min22sec (total time)
This is with double resolution (actually my daily output resolution) 33min total time ( total depth 8, diffuse&glossy&specular 4)
This is the denoised image
I'd like to save the lightcache solution, load it and render this scene with GPU.... :)
In any case a great improvement for this kind of scenarios.
Great job
edit: I didn't understand how to denoise the image with different settings after the render is finished. The "run denoiser" button is always grey (disabled)
marcatore wrote: Thu Jul 05, 2018 7:54 am edit: I didn't understand how to denoise the image with different settings after the render is finished. The "run denoiser" button is always grey (disabled)
Denoising after the render is finished is not possible.
I'd like to say "currently" but I fear it is not really solvable because of Blender API limitations (see https://github.com/LuxCoreRender/BlendL ... -398390095)
marcatore
Post by marcatore »
So, if I'd like to test different settings, what should be the workflow?
Something like:
- launch render
- when I'm quite satisfied of the sampling, I press Pause of the render
- then in the image editor I change the denoiser settings
is it correct?
It works quite well, good.
marcatore wrote: Thu Jul 05, 2018 7:54 am I'd like to save the lightcache solution, load it and render this scene with GPU.... :)
I'm going to add the option to have persistent light cache, saved on file: for camera-only animations it will be possible to use the same cache for all frames. OpenCL support will be the next step once things are settle down.
marcatore wrote: Thu Jul 05, 2018 8:27 am Something like:
- launch render
is it correct?
Yes.
