rendering conflict with viewport?
Burk
Post by Burk »
Windows 10, Blender 2.79b, Luxcore 2.0
Rendering with LuxCoreRender (F12) sometimes results in an error message:
Sometimes the rendering runs without this error messages. It seems that this error occurs often when the viewport shading is set to "rendered" and the viewport view ist moved (Shift + MMB) or zoomed (scroll wheel) while rendering.
See example:
LuxCorerender conflict with viewport.blend
(809.51 KiB) Downloaded 372 times
Re: rendering conflict with viewport?
You mean you have a final render and a viewport render running in parallel?
Burk
Post by Burk »
Yes.
I was used to doing so with Cycles and Blender Internal, quite comfortable.
Ok, this is a scenario I never tried.
When I have time again (in about 3 weeks) I'll try to investigate and ask the Blender devs why the "Writing to ID classes is not allowed"-error shows up.
Burk
Post by Burk »
OK, no hurry. It's only comfort.
The final rendering whithout viewport rendering works fine.
Thanks!
