I was rendering a project, and after 17h the render was stopped with this error:
(34, 'Result too large')Code: Select all
[LuxCore][56723.813] Convergence test: ToDo Pixels = 2558081, Max. Error = 0.154041 [39.4346/256]
[LuxCore][57174.047] Convergence test: ToDo Pixels = 2554849, Max. Error = 0.457628 [117.153/256]
[LuxCore][57624.219] Convergence test: ToDo Pixels = 2550975, Max. Error = 0.247707 [63.4131/256]
[LuxCore][58074.000] Convergence test: ToDo Pixels = 2549558, Max. Error = 0.17041 [43.625/256]
[LuxCore][58523.813] Convergence test: ToDo Pixels = 2545434, Max. Error = 0.14843 [37.998/256]
[LuxCore][58974.172] Convergence test: ToDo Pixels = 2542347, Max. Error = 0.16177 [41.4131/256]
[LuxCore][59424.453] Convergence test: ToDo Pixels = 2537048, Max. Error = 0.148994 [38.1426/256]
[LuxCore][59874.391] Convergence test: ToDo Pixels = 2531289, Max. Error = 0.30172 [77.2402/256]
[LuxCore][60324.157] Convergence test: ToDo Pixels = 2527076, Max. Error = 0.139156 [35.624/256]
[LuxCore][60774.016] Convergence test: ToDo Pixels = 2523247, Max. Error = 0.162209 [41.5254/256]
[LuxCore][61224.032] Convergence test: ToDo Pixels = 2521013, Max. Error = 0.172817 [44.2412/256]
[LuxCore][61674.172] Convergence test: ToDo Pixels = 2517465, Max. Error = 0.214511 [54.9148/256]
File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 45, in render_final
final.render(self, scene)
File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 36, in render
_render_layer(engine, scene)
File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 87, in _render_layer
update_stats = (now - last_stat_refresh) > _stat_refresh_interval(start, scene)
File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 174, in _stat_refresh_interval
return max(min(2**minutes, maximum), minimum)
OverflowError: (34, 'Result too large')
ERROR: (34, 'Result too large')
[LuxCore][62078.703] [GeForce GTX 1080 Ti Intersect] Memory used for OpenCL image pipeline: 101013Kbytes
[Exporter] Init
Error: (34, 'Result too large')Regards
