My problem is that in BlendLuxCore LuxCore Config clicking the OpenCL option it doesn't show my GPU as an available device. I have tried dozens of different ways to make my £100 graphics card work :<
I am using Blender 2.79b and BlendLuxCore 2.0 and my PC Specs are as follows:
CPU:Intel Pentuim G4560
GPU:AMD Radeon R9 270X
RAM:4GB DDR4
Motherboard:B250M Mortar
Any help will be appreicated.
Graphics Card Not Showing Up
Re: Graphics Card Not Showing Up
Start to check if your OpenCL support is working fine by trying to run LuxMark ? Does it work ?Rqindash wrote: Fri Jun 01, 2018 9:23 am My problem is that in BlendLuxCore LuxCore Config clicking the OpenCL option it doesn't show my GPU as an available device. I have tried dozens of different ways to make my £100 graphics card work :<
Check also if you have downloaded and installed the BlendLuxCore version with OpenCL support (and not the one without) from the Download page.
LuxMark does not work with my GPU installed however it does with my Intergrated Graphics
I am also using the OpenCL version
I think it is something to do with my card. I will try to fix.
Don't worry, I just needed to reinstall Windows as I installed my GPU prior to Windows installation.
