PBR node setup
kumaran7
PBR node setup
Post by kumaran7 »
Hi guys can anyone post Luxcore PBR node setup like useing substance painter textures.
S0rda
Re: PBR node setup
Post by S0rda »
And me, please. I think this is not very different from how to add textures to Cycles.
Re: PBR node setup
If you upload some example textures I can create an example node setup.
S0rda
Re: PBR node setup
Post by S0rda »
Just attach the image of the chain of nodes.
Re: PBR node setup
I need some textures to work with, I can't create a setup out of thin air.
All LuxCore materials are "physically based", so strictly speaking any node setup is "PBR".
But I assume that you mean a setup for textures from Unreal Engine, Substance Painter or something like that.
You can also post a link to a set of textures similar to the one you want to use in your project.
Re: PBR node setup
By the way, here's an old thread on this topic: http://www.luxrender.net/forum/viewtopi ... br#p126895
kumaran7
Re: PBR node setup
Post by kumaran7 »
Ill try friends,im new to blender but i like lux more than cycles.
kumaran7
Re: PBR node setup
Post by kumaran7 »
Can some one post PBR brick wall node setup
