* Done creating target tree
* Checking libstdc++
* Library symlink is missing, attempting to figure out the proper location
!!! Unable to find libstdc++.a at known locations.
!!! You have to find the library manually and symlink
!!! it to the following path:
!!! /home/joc/Programme/LuxCore/LinuxCompile/target-64-sse2/lib/libstdc++.a
found, linked, no problem, but next launch asks for
* Done checking distfiles
* Checking target tree
* Target tree exists
* Done checking libstdc++
* Checking python
!!! Unable to find libpython3.6.a or libpython3.6m.a at known
!!! locations. You have to find the library manually and
!!! symlink it to the following path:
!!! /home/joc/Programme/LuxCore/LinuxCompile/target-64-sse2/lib/libpython3.6.a
I could not find yet a package or repo containing this library...
Sorry, somehow I broke my system. Opensuse Tumbleweed. Python 3.6 package is without static library indeed. I've build one from source now, made a symlink to the build and compiling went on to:
test_prefix = /home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2
checking for pkg-config... /usr/bin/pkg-config
using ilmbase-prefix to set ILMBASE_CXXFLAGS, ILMBASE_LDFLAGS and ILMBASE_LIBS:
ILMBASE_CXXFLAGS = -I/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/include/OpenEXR
ILMBASE_LDFLAGS = -L/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/lib -L/usr/lib64 -L/usr/local/lib
ILMBASE_LIBS = -lImath -lHalf -lIex -lIlmThread -lpthread
checking for IlmBase... no
*** Could not run the IlmBase test program, checking why...
*** The IlmBase test program could be compiled, but could not be dynamically.
*** or statically linked.
*** Make sure the LDFLAGS points to the location of the IlmBase library.
*** (e.g. -L/usr/local/lib).
*** If the run-time linker is not finding IlmBase, you'll need to set your
*** LD_LIBRARY_PATH environment variable, or edit /etc/ld.so.conf to point
*** to the installed location Also, make sure you have run ldconfig if that
*** is required on your system.
*** Flags used by the test:
*** cflags: -w -mtune=generic -std=gnu++98 -mmmx -msse -msse2 -O2 -pipe -mfpmath=sse -fPIC -I/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/include/OpenEXR
*** ldflags: -L/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/lib -static-libgcc -static-libstdc++ -L/home/joc/Programme/LuxCoreEnv/LinuxCompile/target-64-sse2/lib -L/usr/lib64 -L/usr/local/lib
*** You can also run configure with --disable-ilmbasetest to skip this test.
configure: error: Could not compile IlmBase test program.
!!! openexr configuration failed
