How can I change the interpolation of image textures?
happysmash27
Post by happysmash27 »
I am trying to change the interpolation of an image texture to be nearest neighbour, with sharper, cleaner lines. However, I don't see an interpolation option. Is it currently possible to do this without manually making the texture larger? Reference image, with LuxCoreRender on the left and original Cycles render on the right:
Re: How can I change the interpolation of image textures?
happysmash27 wrote: Wed May 09, 2018 3:23 am I am trying to change the interpolation of an image texture to be nearest neighbour, with sharper, cleaner lines. However, I don't see an interpolation option. Is it currently possible to do this without manually making the texture larger?
Not at the moment, bilinear interpolation is always used. Indeed, it would be quite easy to add as an option but it has never be done until now.
igmar75
Post by igmar75 »
Hello, the option to disable the interpolation is still absent?
igmar75 wrote: Fri Oct 30, 2020 1:37 pm Hello, the option to disable the interpolation is still absent?
Yup.
