You need blendluxcore for Blender v4
on Blendluxcore it work :
Blender 4 compatibility
- FarbigeWelt
- Contact:
blendluxcore_v2.8alpha1
Great! Thanks to Sharlybg who shared the information LuxCore runs in Blender 4.0 now I installed BlendLuxCore_v2.8alpha1 on my M1 MacBook Air 16 GB. And YES LuxCoreRender runs in Blender 4.0.2 Intel on my Mac. But not for long. As soon I saved a file with default cube set to material "Glass" and reloaded the scene neither viewport nor final render ran without error messages. I wrote an issue in https://github.com/LuxCoreRender/BlendL ... issues/897 but didn't got any feedback since. So I decided to give BlendLuxCore_v2.8alpha1 another try today starting Blender from Terminal to get messages logged, see github.
EDIT
Comment on github:
After switching from OpenCL to CPU Viewport renders nicely.
New Viewport render:
Great Work so far. Thank You ..
EDIT
Comment on github:
After changing "Film Device" in Render:"LuxCoreRender" from GPU to CPU rendering in Viewport runs without errors using "Compute Device" CPU.
After switching from "Compute Device" CPU to GPU BlendLuxCore initiated compiling openCL kernel after starting a final render. Just a few minutes later final render started using GPU.
Changing "Film Device" back to "Apple M1 (OPENCL)" threw again an error message:"OpenCL driver API error ..." switching to CPU started rendering in Viewport immediately.
[LuxCore][83.301] Film hardware image pipeline
[b][LuxCore][83.305] Film hardware device used: Apple M1 OpenCLIntersect (Type: OPENCL_GPU)[/b]
[LuxCore][83.306] Device OpenCL version: OpenCL 1.2
[LuxRays][83.307] [Device Apple M1 OpenCLIntersect] IMAGEPIPELINE buffer size: 57006Kbytes
[LuxRays][83.356] [Device Apple M1 OpenCLIntersect] Merge buffer size: 76008Kbytes
[LuxRays][83.357] [MergeSampleBuffersOCL] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D LUXRAYS_OPENCL_DEVICE -D LUXRAYS_OS_APPLE -cl-fast-relaxed-math -cl-mad-enable
[LuxRays][83.357] [MergeSampleBuffersOCL] Compiling kernels
File "/Users/michael/Library/Application Support/Blender/4.0/scripts/addons/BlendLuxCore/engine/base.py", line 128, in view_draw
viewport.view_draw(self, context, depsgraph)
File "/Users/michael/Library/Application Support/Blender/4.0/scripts/addons/BlendLuxCore/engine/viewport.py", line 238, in view_draw
framebuffer.update(engine.session, scene)
File "/Users/michael/Library/Application Support/Blender/4.0/scripts/addons/BlendLuxCore/draw/viewport.py", line 199, in update
luxcore_session.GetFilm().GetOutputFloat(self._output_type, self.buffer)
[b]RuntimeError: OpenCL driver API error (code: -30, file:/Users/runner/work/1/s/src/luxrays/utils/ocl.cpp, line: 371): CL_INVALID_VALUE[/bNew Viewport render:
[Engine/Viewport] New session
[Exporter] Creating session
Updated node "Glass Material" in tree Material to new version
[SDL][12166.312] Define ImageMap: NamedObject
[SDL][12166.312] Camera type: perspective
[SDL][12166.312] Camera position: Point[7.35889, -6.92579, 4.95831]
[SDL][12166.312] Camera target: Point[6.70733, -6.31162, 4.51304]
[SDL][12166.312] Camera clipping plane disabled
WARNING: No material defined
[SDL][12166.315] Material definition: 140653016094520
[SDL][12166.315] Material definition: __CLAY__
[SDL][12166.316] Scene objects count: 2
[SDL][12166.316] Light definition: 140653599499272
[SDL][12166.316] Light definition: __WORLD_BACKGROUND_LIGHT__
[LuxCore][12166.344] Configuration:
[LuxCore][12166.344] path.pathdepth.total = 13
[LuxCore][12166.344] path.pathdepth.diffuse = 9
[LuxCore][12166.344] path.pathdepth.glossy = 9
[LuxCore][12166.344] path.pathdepth.specular = 12
[LuxCore][12166.344] path.hybridbackforward.enable = 0
[LuxCore][12166.344] path.hybridbackforward.partition = 0.8
[LuxCore][12166.344] path.hybridbackforward.glossinessthreshold = 0.049
[LuxCore][12166.344] rtpathcpu.zoomphase.size = 4
[LuxCore][12166.344] rtpathcpu.zoomphase.weight = 0
[LuxCore][12166.344] renderengine.type = "RTPATHCPU"
[LuxCore][12166.344] sampler.type = "RTPATHCPUSAMPLER"
[LuxCore][12166.344] film.width = 1387
[LuxCore][12166.344] film.height = 780
[LuxCore][12166.344] film.filter.type = "NONE"
[LuxCore][12166.344] film.filter.width = 1.5
[LuxCore][12166.344] lightstrategy.type = "LOG_POWER"
[LuxCore][12166.344] scene.epsilon.min = 1e-05
[LuxCore][12166.344] scene.epsilon.max = 0.1
[LuxCore][12166.344] path.albedospecular.type = "REFLECT_TRANSMIT"
[LuxCore][12166.344] path.albedospecular.glossinessthreshold = 0.05
[LuxCore][12166.344] film.opencl.enable = 0
[LuxCore][12166.344] path.forceblackbackground.enable = 0
[LuxCore][12166.344] renderengine.seed = 1
[LuxCore][12166.344] film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][12166.344] film.outputs.0.index = 0
[LuxCore][12166.344] film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][12166.344] film.imagepipelines.000.0.type = "NOP"
[LuxCore][12166.344] film.imagepipelines.000.1.type = "TONEMAP_LINEAR"
[LuxCore][12166.345] film.imagepipelines.000.1.scale = 1
[LuxCore][12166.345] film.imagepipelines.000.radiancescales.0.enabled = 1
[LuxCore][12166.345] film.imagepipelines.000.radiancescales.0.globalscale = 1
[LuxCore][12166.345] film.imagepipelines.000.radiancescales.0.rgbscale = 1 1 1
[LuxCore][12166.345] batch.haltspp = 0 0
[LuxCore][12166.345] batch.halttime = 60
[LuxCore][12166.345] File Name Resolver Configuration:
Export took 0.0 s
[LuxCore][12166.345] Film resolution: 1387x780
[SDL][12166.345] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][12166.345] Image pipeline: film.imagepipelines.000
[SDL][12166.345] Image pipeline step 0: NOP
[SDL][12166.345] Image pipeline step 1: TONEMAP_LINEAR
[SDL][12166.346] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[LuxRays][12166.346] OpenCL support: enabled
[LuxRays][12166.346] OpenCL Platform 0: Apple
[LuxRays][12166.346] CUDA support: enabled
[LuxRays][12166.346] Device 0 name: Native
[LuxRays][12166.346] Device 0 type: NATIVE_THREAD
[LuxRays][12166.346] Device 0 compute units: 1
[LuxRays][12166.346] Device 0 preferred float vector width: 4
[LuxRays][12166.346] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][12166.346] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][12166.346] Device 0 has out of core memory support: 0
[LuxRays][12166.346] Device 1 name: Apple M1
[LuxRays][12166.346] Device 1 type: OPENCL_CPU
[LuxRays][12166.346] Device 1 compute units: 8
[LuxRays][12166.346] Device 1 preferred float vector width: 4
[LuxRays][12166.346] Device 1 max allocable memory: 16384MBytes
[LuxRays][12166.346] Device 1 max allocable memory block size: 4096MBytes
[LuxRays][12166.347] Device 1 has out of core memory support: 0
[LuxRays][12166.347] Device 2 name: Apple M1
[LuxRays][12166.347] Device 2 type: OPENCL_GPU
[LuxRays][12166.347] Device 2 compute units: 8
[LuxRays][12166.347] Device 2 preferred float vector width: 1
[LuxRays][12166.347] Device 2 max allocable memory: 10922MBytes
[LuxRays][12166.347] Device 2 max allocable memory block size: 2048MBytes
[LuxRays][12166.347] Device 2 has out of core memory support: 0
[LuxRays][12166.347] Creating 8 intersection device(s)
[LuxRays][12166.347] Allocating intersection device 0: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][12166.347] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxCore][12166.347] Configuring 8 CPU render threads
[LuxRays][12166.347] Preprocessing DataSet
[LuxRays][12166.347] Total vertex count: 28
[LuxRays][12166.347] Total triangle count: 14
[LuxRays][12166.347] Preprocessing DataSet done
[LuxRays][12166.347] Adding DataSet accelerator: EMBREE
[LuxRays][12166.349] EmbreeAccel build time: 1ms
[Engine/Viewport] Pausing session
Re: Blender 4 compatibility
Hi friends! Is there any update on progress here? I miss my LuxCore in Blender
If I knew how to help, I would.
- Odilkhan Yakubov
Hi. At least for Blender 4.0.3 but not updated for Blender 4.1 or so. The main reason is in Blender 4.1 Python version has been changed to v3.11 from v3.10 and other deps too and this will be issue for LuxCoreRender v2.8+aprilwine wrote: Sun Apr 21, 2024 3:13 am Hi friends! Is there any update on progress here? I miss my LuxCore in BlenderIf I knew how to help, I would.
