Chair Stitching more visible in Cycles
RichardH
Post by RichardH »
Hi
I was wondering why the stitching in the arm of this chair is more visible in Cycles than in Lux. Overall, the Lux Velvet material is far nicer than the Cycles one but the stitching is just using the Disney shader set to the same settings in Cycles and in Lux
I appreciate that the lighting is a bit brighter in the Cycles version, but even when I change it it doesn't seem to make any difference.
Many thanks
https://1drv.ms/u/c/e39f680ee914d5e9/ES ... g?e=oeAly3
Luximage
Re: Chair Stitching more visible in Cycles
Post by Luximage »
See if in Luxcore the material output active is checked or try using the glossy material instead of disney.
You could also set clamping a bit higher.
Anyway, here's a take on it (@wetransfer).
RichardH
Post by RichardH »
Thank you kintuX. That's become much more visible in the downloaded file :)
modhob
Post by modhob »
the shadowing under the pillows on the lux image looks weird. Like white, instead of the shadows you see in the Cycles version
It looks quite unnatural because of strong 'sheen' effect (Velvet's Thickness). But can be remedied, either by lowering 'Thickness' or mixing it w/ "Disney" and using its "sheen" effect. It's just an artistic choice :)
eg
(later/mix)
