What happens with Pointnes Scene in 2.6 and later
Snowcarver
Post by Snowcarver »
Hello everyone!
Something happens with.. scene or engine or..
Re: What happens with Pointnes Scene in 2.6 and later
Wich blender version are you On ?
If not 3.4 go back to it.
Snowcarver
Sharlybg wrote: Thu Jun 29, 2023 10:35 am Wich blender version are you On ?
It was opened on 2.93 and 2.6 release Luxcore.
At first, I opened scene on 3.5 and automatic build. I thought, that is because of 3.5. After downloading 2.93 and 2.6 release i got same result, unfortunately. I remember, it worked any time ago, but now something happens(.
UPD: 3.4 gives same result(.
Here is pointness under Blender 3.41 and blendluxcore lastest :
https://github.com/LuxCoreRender/BlendL ... tag/latest
Snowcarver
Thank You! Maybe, its because of algorithms was changed.. For me Pointness is inconceivable thing.. Big thanks for a simple solution and understandable node tree!
Luximage
Post by Luximage »
I remade the scene to work with luxcore 2.6:
PointinessExamples luxcore 2.6.blend
(1.64 MiB) Downloaded 778 times
It was not working because in version 2.6 the pointer node does not work properly, in blender 2.92 with luxcore 2.5 the original file also works fine.
Also, works fine on Blender 3.6.0 LTS w/ BLC 2.71beta
tnx Luximage!
Luximage
Post by Luximage »
Thank you kintuX , nice to know it also works with the latest version and blender 3.6!
