Glass ad caustic issue
Re: Glass ad caustic issue
Dade wrote: Sun Apr 18, 2021 8:08 pm Try to rise the glasses if the bottom is touching the aground plane, it can be a problem.
I assume you have already raised the path max. depth too.
Amazing that solve the problem.
kybio
Post by kybio »
Hi TAO, How did you solve the inner shadow? Would you be able to share the last test configuration?
