u3dreal
Post by u3dreal »
Again this stupid Mono Framework ....
I'll update later.
portfolio http://q3de.com/
u3dreal
Post by u3dreal »
OK now all should be ....
MCurto
Post by MCurto »
I really hate to be the person that keeps nagging and saying it isn't.
Last build of 17h ago, in 3.41 installs, but when you switch to rendered view gives unspecified error:
I don't know to what error log it refers to, couldn't find any in my temp folder (open $TMPDIR), or any other relevant locations like Home or Blender App support in Library.
I ran Blender trought terminal with debug (don't know if there's a specific flag for Lux)
Debug file:
https://drive.google.com/file/d/1jyei1G ... share_link
Then the same release runs just fine after it compiles kernels in 3.3. But going back to 3.4 has the same behaviour
:shock:
EDIT: Also found this, presumably written by you (?) , is it still relevant to new Mac versions?:
https://wiki.luxcorerender.org/Compilin ... _10.13_.2B
BTW: I keep working in 3.3.3 and all is fine, have no issues with the Lux reselase not working in 3.4x , maybe just better to keep a warning somewhere there are compatibility issues with 3.4.x?
u3dreal
Post by u3dreal »
You can find it here ... i had something similar but after rendering the viewport works ...
The jpeg error is gone though.
what is you error ?
MCurto
Post by MCurto »
Same as yours? CUDA? :roll:
And yes, its viewport only, it renders fine, even the Oranje Juice scene that was throwing errors.
u3dreal
Post by u3dreal »
It seems to be acociated with viewport denoising beeing enabled ... all works when disabled
MCurto
Post by MCurto »
Right....
also, there's no option in 3.4 to change Denoiser for Viewport:
3.3:
Surely that's the problem
u3dreal
Post by u3dreal »
RuntimeError: module compiled against API version 0x10 but this version of numpy is 0xf
ImportError: numpy.core._multiarray_umath failed to import
it seems numpy is wrong version ..... will test
u3dreal
Post by u3dreal »
No that was not the problem ..
File "/Volumes/TOSHIBA_EXT/GitHub/Blender_Addons_2020/addons/BlendLuxCore/ui/render/viewport.py", line 68, in draw
can_use_optix = viewport.can_use_optix_denoiser(context)
File "/Volumes/TOSHIBA_EXT/GitHub/Blender_Addons_2020/addons/BlendLuxCore/properties/viewport.py", line 71, in can_use_optix_denoiser
if data.Get(prefix + ".cuda.compute.major").GetInt() >= 5:
RuntimeError: Undefined property in Properties::Get(): opencl.device.1.cuda.compute.major
seems to be a missing property ... now it is time to ask if this is only macOS ... does anyone have this problem on win etc ?
neo2068
Post by neo2068 »
I recently added this check to only run OPTIX denoiser on newer Nvidia cards but this seems to give an error for non NVIDIA cards. I will push a fix soon.
