Two side shader reflection broken ?
Luximage
Re: Two side shader reflection broken ?
Post by Luximage »
Odilkhan try putting something to be reflected in both sides, i don't see anything reflected in the blue side which is the backface.
The backface reflection is broken in general for the disney and glossy material in version 2.62.1a , it's not only a problem with the 2sided material, just
assign a disney or glossy material (not with 2sided material) and see that reflections don't appear in the backface.
Even in version 2.5 the backface can only produce reflections with a disney material and not with the glossy.
Odilkhan Yakubov
Post by Odilkhan Yakubov »
Luximage
Post by Luximage »
Odilkhan the metal and mirror material work, I was talking about the disney and glossy material.
In my example both planes have the same material, as you can see the horizontal plane has no reflections.
Odilkhan Yakubov
Luximage wrote: Fri Dec 23, 2022 1:49 pm Odilkhan the metal and mirror material work, I was talking about the disney and glossy material.
Hm, I got it now. It doesn't work not on latest build but also on previous builds too. It seems it doesn't works with Glossy, Glossy translucensies mats.
Odilkhan Yakubov
Latest Official BlendLuxCore v2.61 is out:
https://github.com/LuxCoreRender/BlendL ... tag/latest
