Two side shader reflection broken ?
Hi ,
As the Title suggest i'm not able to get reflection on the back side of any geometry even while using
Two side material shader.Here is the blend and the screen capture.
Blend
https://drive.google.com/file/d/1wnweaW ... sp=sharing
Re: Two side shader reflection broken ?
Hi Dade, can you try to catch this one please? In some modelers there is no normal orientation control at all, for example Autocad. So it's really useful to have a two sided shader which eliminates the problem at the origin.
Thanks
Right, seems like a bug.
Cycles & other engines do fine with reflections, no matter which way normals are directed.
eg
Lux
Cycles
Post by epilectrolytics »
Mirror and Metal materials work two-sided, Disney and Glossy only one-sided :?
Hi guys, can someone help me to identify the latest luxcore version where the two sided option was working on disney shader? We want to try to fix it. Thanks
Luximage
Post by Luximage »
In 2.5 version the 2sided material works.
Odilkhan Yakubov
Post by Odilkhan Yakubov »
daros wrote: Wed Dec 21, 2022 11:10 am Hi guys, can someone help me to identify the latest luxcore version where the two sided option was working on disney shader? We want to try to fix it. Thanks
Hi @Daros. BlendLuxCore v2.62.1a works fine with Disney shader in Two-sided material:
https://github.com/odil24/BlendLuxCore/ ... g/v2.62.1a
Thanks a lot Odilkhan!
Luximage
Post by Luximage »
In version 2.62.1a from my test the reflection in 2sided material for the glossy and disney material doesn't work.
Odilkhan Yakubov
Luximage wrote: Wed Dec 21, 2022 2:47 pm In version 2.62.1a from my test the reflection in 2sided material for the glossy and disney material doesn't work.
