LuxCore
david57
LuxCore
Post by david57 »
Here is an old sketchUp model i made.
Racleborg
Re: LuxCore
Post by Racleborg »
It's a great model, but what's that bit in the middle of the attached pic? It looks like some tiles are floating in mid-air.
david57
Re: LuxCore
Post by david57 »
Lol, yes. I tried selecting and deleting that portion of tiles but its joined to
other tiles. Can not go into edit mode. Have to repair that problem with SketchUp.
Could be a bug with blender but dont want to go through the hassle of reporting it.
Have gone through to many bugs here already. :)
Racleborg
Re: LuxCore
Post by Racleborg »
If you would like to upload the file either as a blend or step I could take a look at it for you. I'm not a Blender expert, but not bad at TopSolid.
david57
Re: LuxCore
Post by david57 »
An update.
I removed a ground plane covering the sidewalk and road.
This is getting boring. I want to work on an interior scene.
zezic
Re: LuxCore
Post by zezic »
This bush is superb :)
david57
Re: LuxCore
Post by david57 »
The bush is from ngPlant.
I was checking out both renders and when I removed the ground plane it removed some reflection on the side
of the walls.
This is a sketchUp image:
david57
Re: LuxCore
Post by david57 »
Trees and bushes made with ngPlant.
