Dez! projects
Re: Dez! projects
Yes. This is my favorite node
Re: Dez! projects
Re: Dez! projects
weldone Dez, keep up the good job.
viewtopic.php?f=5&t=1010&start=590#p30154
artstation https://www.artstation.com/omidghotbi
Re: Dez! projects
Thank you!
Actually my ryzen 5 5600x is running around the clock at 11 threads. i do a lot of Luxcore rendering. But I don't see these jobs as interesting, they are all the same, "turnover", working freelancer routine
I had to try a lot of rendering on render farms, I tried to create my own on AWS servers, I went through two months of working in Cinema4D and here I am back. The whole journey was not in vain - from it I brought out diamonds of experience and knowledge. And Luxcore has finally become commercially viable to use.
Re: Dez! projects
The quality you can get with luxcore is simply amazing. good to see you enjoy it too.
Re: Dez! projects
Luxcore has firmly established itself in my workflow as the best lighting visualizer
Re: Dez! projects
Right now I'm doing a huge project with these simple elements. Large Luxcore rendering flow
Re: Dez! projects
