Problem with volume and lights
Flink
Post by Flink »
I'm working currently on an underwater scene and discovered some odd behavior of lights in volumes.
The Power of the lights is not as expected. I am not sure if it is some kind of bug or wrong settings.
Here is an example scene:
I set world, camera and the volumes on the light sources but the area light seems off.
Both the mesh light and the area light in the example scene have the same size and power.
The scene is rendered with BiDir Engine.
Blender Version is 2.93.8 with LuxCore Version 2.6
LightsVolumeExample.blend
(868.85 KiB) Downloaded 1475 times
Re: Problem with volume and lights
This look like a bug I have tried few things but it saty exactly the same.
Worse I have even found another strange behaviour:
Adding a point Light source to the scene will make it like a kind of
Black hole absorbing all rays in the scene:
Works fine here.
It's just that your "World needs to know its Volume" ;)
Great Kintux Just jump straight thinking this was already set
as the two other were working ;)
Flink
Post by Flink »
Thanks Kintux, that works great :D
But I don't understand, why it makes a difference.
The description of the world volume says:
"Default Volume (used on materials without attached volume)"
But i set the volume on the area light. So this should be used instead of the world volume :?:
Flink
Post by Flink »
I did another test with some kind of a fish tank and have the next problem :roll:
How do I set the volumes correctly in this case?
The outside of the tank is in contact with two volumes.
LightsVolumeExample2.blend
(1.36 MiB) Downloaded 1480 times
Flink wrote: Wed Apr 06, 2022 7:52 pm I did another test with some kind of a fish tank and have the next problem :roll:
To work like this?
Camera > Auto-Volume
MeshLight > World Volume
Point Light > HitPlane added
Disclaimer:
Based on your model,
what's "correctly set" here is arbitrary.
LightsVolumeExample2(hack)blend.blend
(1.37 MiB) Downloaded 1495 times
Flink
Post by Flink »
Thank you kintuX, really appreciate your help :)
That is the result I was looking for. But i don't understand why it is working like this.
Why does the meshlight need the world_volume aka. air when it is under water :?:
Is it just because of my ugly setup?
If we start with an empty scene. How would the correct way be to setup a submersed camera in a tank with some lights?
Learn further, read & practice some more...
Test Underwater Paintings scene, check docs, tuts, explore forums... basically, construct knowledge with experience.
Example Scenes
Flink
Post by Flink »
Hi kuntuX, once again thank you for your support :)
I did some more tests and got results I'm happy with.
It is just a rough layout of the scene with nearly no textures, but the lighting goes in the right direction.
Here is a denoised version of the rendering (low path depth). Any advises how to further improve the setup?
