Import Image as Plane issue
MikeE
Post by MikeE »
I am new to Blender and LuxCore. I am having an issue which I cant seem to find any solutions to online, so I suspect it is something very basic I am doing wrong.
I am trying to add a decal to a model by using the Import --> Image as Plane addon. As soon as I click it, I get an error message
"Cannot generate materials for unknown LUXCORE render engine".
If I switch Render Engine from LuxCore to say Cycles or Eevee then it works fine and brings up the file dialogue for selecting the image.
I am using Blender 3.1 with the experimental builds. The LuxCore render engine is working fine for me in all other regards - I have created renders successfully, just without the decals.
I also tried Blender 2.93 with the stable addon and I get the same issue.
Hopefully someone can embarrass me with a fundamental understanding I am missing.
Cheers
sarmath
Re: Import Image as Plane issue
Post by sarmath »
Hi. This addon is working only with Cycles and Eevee. But you can use it with cycles first then switch to luxcore and recreate material for the imported image on plane.
