B.Y.O.B. wrote: Tue Apr 24, 2018 6:37 am
The missing error message was a regression, I fixed it yesterday.
As a workaround, you can see the message in the console.
Yes, got a file file "Cr2.nk"
Cr2.zip
- (1016 Bytes) Downloaded 549 times
used as:
1. Lux Pop
"Error: | Unparseable luxpop data in: X:\...\Cr2.nk"
and another from (
nk sopra source)
2. Sopra
"Error: | Bad sopra header in X:\...\Cr.nk"
switching back and forth (with Preview Render running)
Exception ignored in: <bound method LuxCoreRenderEngine.__del__ of <bpy_struct, LuxCoreRenderEngine invalid>>
File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 23, in __del__
if hasattr(self, "_session") and self.session:
ReferenceError: StructRNA of type LuxCoreRenderEngine has been removed
File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\viewport.py", line 19, in view_update
engine.session = engine.exporter.create_session(context)
During handling of the above exception, another exception occurred:
File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 62, in view_update
viewport.view_update(self, context)
File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\viewport.py", line 23, in view_update
del engine.session
File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\export\__init__.py", line 121, in create_session
luxcore_scene.Parse(scene_props)
RuntimeError: Bad sopra header in: D:\_Studies\LuxR\_LuxCoreTests\..\..\..\Nk_data\Cr2.nk
del engine.session
and then, when i switch to Preset (Aluminium) also this:
del engine.session
What, How?
Can i fix this?
