I'm sorry if I spread any misinformation, I did try yesterday and couldn't get it to work (same kind of error i would get in Mac before the 2.6.1 upgrade) retested again today and it does work with latest release on Fedora35. Most probably a user (my) error of some sort.Sry once more.
Azure DevOps pipelines have discontinued the image "macOS-10.14", so MacOS daily builds are now failing.
At the moment this is not a problem: the latest changes are only typo corrections so that the "latest" image is up-to-date also for MacOS.
But can we switch to the image "macOS-10.15", or would that cause problems in the build?
I am a bit reluctant to just try it in order not to lose the available and working MacOS binaries.
U3dreal, could you please look into this, or let me know if I can just change to the newer image?
Tried to get it to work with blender 3.0 and latest daily build, kernel compilation error.
What OS?
W10, Blender 3.01RC and Latest BlendLuxCore 2.61 (homebrew) works fine.
Only issues have lately started to appear w/ Blender 3.1 Alpha (corrupt geo).
Sorry, I didn't point it out right away. win10
A-ok, could you please make a thread and post specifics (console error report, steps to repro...) in User Support forums
this one is reserved for auto-building issues.
Thanks
I am experiencing the same thing for 2.6 on 2.93.4ltsMCurto wrote: ↑Sun Jan 09, 2022 11:13 pm I'm sorry if I spread any misinformation, I did try yesterday and couldn't get it to work (same kind of error i would get in Mac before the 2.6.1 upgrade) retested again today and it does work with latest release on Fedora35. Most probably a user (my) error of some sort.Sry once more.
I'd like to test the latest daily build with the Blender 3.1 support but when I follow the link I see this
and I can't see the zip files.
Something wrong by me or by the building system?
Hi, yes, apparently there has been a problem in the automatic build for BlendLuxCore.
I have run the pipeline again, hopefully everything's ok again in some minutes.
EDIT: It failed again, I have now run everything from scratch, including LuxCore. It will take 1 hour or so, let's see...
EDIT 2: it looks all right now
