Hello,
I applied the shadow color white to the glass, but the ray that pass through the glass become more bright than where is not the glass.
please correct this issue.
I attach also the blender scene.
thanks
shadow color for glass issue
- glass-shadow color.blend
- (1.53 MiB) Downloaded 754 times
Re: shadow color for glass issue
thanks a lot for the fix. I will check soon.
Hi do you experience the same problem with shadow color?
bidir cpu - normal shadow color
this one is as expected by knowing the caustics-through glass problem
bidir cpu - white shadow color
should not cast shadow on the red object
PhotonGI on CPU glass normal shadow color
https://drive.google.com/file/d/1s02Zb8 ... sp=sharing
It increases the brightness of the area below the glass which is not expected.
\https://drive.google.com/file/d/1-vMFfh ... sp=sharing
tomorrow morning i post the scene
Is the shadow color 100% white in both cases ?
Hi sharlybg, it is full white in the second and in the fourth example. In the first and the third it is black.
Here is the luxcore scene
Have you checked your geometry? Your issues stem from that mess.
A small advice.
Consistency. If you want your simulation to run as intended & physically correct, do your work in same manner - precise & concise , according to as IRL, or simply choose more forgiving, biased engine.
A small advice.
Hi kintux,
sorry i do not understand... what is wrong with this geometry? It's a very simple scene.
Below you find the obj.
light test.rar- (4.48 KiB) Downloaded 657 times
It's simple alright, and it's also reason why I'm shocked.
So, see what are " Overlapping polygons, Intersecting geometry, Walls w/o Thickness...
For further endeavors try and go by Forum rules described on top.
PS
"Testscene" in Blender format. Otherwise, who knows what's going on and it looks like even yourself have issues with basic fundamentals.
PPS.
Goes for your first scene and this latest .obj.
Just learn some from exemplary scenes...
https://luxcorerender.org/example-scenes/
PS
PPS.
