BlendLuxCore Development
Re: BlendLuxCore Development
B.Y.O.B. wrote: Mon Apr 23, 2018 9:03 am
kintuX wrote: Mon Apr 23, 2018 8:51 am Within the scene file here there's a model (bottle > circle) where the node that needs UV (ie. Glossy Coating Material) states: "No UV map" (That's specifically what i was wondering about.)
Is the mapping working correctly in the rendered image?
The check only looks for a UV map in a mesh datablock, it probably does not even work for curves. If the mapping is working correctly and only the warning is shown, then I will have to correct the code for the warning.
Looks like it's working fine (to be 100% sure, will compare to Cycles later). Thanks.
eg
Fresnel File with Metal Material bug?
IIRC there was an Error notification, if wrong file was selected and used for Metal Fresnel File (Lux Pop / Sopra) :?
Now all it does does is nothing (render halts, material preview goes black, render preview transparent as alpha) so user is left to wonder... what? why?
eg
The missing error message was a regression, I fixed it yesterday.
As a workaround, you can see the message in the console.
I don't know if we already have tis feature but i think if not it could help for better responsivness in realtime preview : this one is for cycles.
Sharlybg wrote: Thu Apr 26, 2018 9:43 am I don't know if we already have tis feature but i think if not it could help for better responsivness in realtime preview : this one is for cycles.
There are specific RTPATHCPU properties to set the initial resolution, etc. so yes, it is possible to add this feature to BlendLuxCore.
B.Y.O.B. wrote: Tue Apr 24, 2018 6:37 am The missing error message was a regression, I fixed it yesterday.
Yes, got a file file "Cr2.nk"
Cr2.zip
(1016 Bytes) Downloaded 478 times
used as:
1. Lux Pop
"Error: | Unparseable luxpop data in: X:\...\Cr2.nk"
and another from (nk sopra source)
2. Sopra
"Error: | Bad sopra header in X:\...\Cr.nk"
switching back and forth (with Preview Render running)
Exception ignored in: <bound method LuxCoreRenderEngine.__del__ of <bpy_struct, LuxCoreRenderEngine invalid>>
  File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 23, in __del__
    if hasattr(self, "_session") and self.session:
ReferenceError: StructRNA of type LuxCoreRenderEngine has been removed
  File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\viewport.py", line 19, in view_update
    engine.session = engine.exporter.create_session(context)
During handling of the above exception, another exception occurred:
  File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 62, in view_update
    viewport.view_update(self, context)
  File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\viewport.py", line 23, in view_update
    del engine.session
  File "C:\Users\py\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\export\__init__.py", line 121, in create_session
    luxcore_scene.Parse(scene_props)
RuntimeError: Bad sopra header in: D:\_Studies\LuxR\_LuxCoreTests\..\..\..\Nk_data\Cr2.nk
    del engine.session
and then, when i switch to Preset (Aluminium) also this:
    del engine.session
What, How?
Can i fix this?
Commits for the bugfix release v2.0.1 are pushed to the bugfix/v2.0.1 branch: https://github.com/LuxCoreRender/BlendL ... fix/v2.0.1
I also created two milestones for the coming releases, they provide an overview of the associated issues:
https://github.com/LuxCoreRender/BlendL ... ilestone/3
https://github.com/LuxCoreRender/BlendL ... ilestone/2
I'm testing if the milestones are enough for project management, they are easier to manage than github projects.
@kintuX: I somehow forgot your post, it happens when it is not a github issue.
Sounds like the files are not correct.
Do they work in other programs?
B.Y.O.B. wrote: Mon May 07, 2018 5:31 pm @kintuX: I somehow forgot your post, it happens when it is not a github issue.
Yeah, i forgot about it too. ;)
B.Y.O.B. wrote: Mon May 07, 2018 5:31 pmSounds like the files are not correct.
They are scientifically correct but it looks like they use different standard. Gonna look into specifics on Luxpop and Sopra standards.
B.Y.O.B. wrote: Mon May 07, 2018 5:31 pmDo they work in other programs?
Tested with Indigo just now and they don't work - error report:
"Only spectral units of eV supported right now..."
All fine :) and thanks again.
In v2.1, there will once again be an option to import multiple image textures at once into the node editor.
I have also added support for reroute nodes (shift + left mouse button to add them).
