PhotonGI cash problem
PetrT
Re: PhotonGI cash problem
Post by PetrT »
kintuX wrote: Sat Aug 28, 2021 7:24 pm Use of PhotonGI Cache makes results a bit darker.
Not sure, but I think it was already mentioned...
This topic about another problem.
Problem with shading solves when Environment Light Cache is turned off
Righty then... not a problem really :D
PetrT
Post by PetrT »
pic of test
PetrT wrote: Sat Aug 28, 2021 7:24 am Test scene https://dropmefiles.com/lJ5Za
I'm looking into the problem.
It looks like the problem is related to the use of constant infinite light, if I replace the light source with an HDR infinite light source, it works fine:
PetrT
Post by PetrT »
thank you
Fu*k, this scene was driving me crazy, I was getting out all kind non sense results.
Your problem is just caused by an extremely low clamping value. If you disable variance clamping (or raise the value by a significative amount). The rendering will be fine.
You were "clamping" a tons of light, this is a rendering with your clamping value:
and this without clamping:
You are clearing cutting half of the transported light (and causing artifacts in the process).
As a reminder this should be put in the tooltips of clamping. ""Too low value can break lighting and create artifacts with GI cache """
PetrT
Post by PetrT »
Dade wrote: Mon Sep 06, 2021 12:50 pm this scene was driving me crazy, I was getting out all kind non sense results.
Sorry,It was not the aim of my post.
I guess just another interesting case
PetrT wrote: Mon Sep 06, 2021 10:08 pm Sorry,It was not the aim of my post.
I'm not sure to understand the statement but I have the feeling you have to run the rendering without clamping to get a valid suggested value.
