I am experimenting with volumes in Luxcore, in Blender, and I have run into an odd problem. Cycles & Renderman seem to handle this automatically. Since OpenVDB is a sparse format the grid size changes for each frame. Since Luxcore treats the grid as a texture, the simulation transforms on every frame. There is a video below highlighting the problems. How do I fix this?
https://www.youtube.com/watch?v=H3WQ_l1gISc
This file also doesn't seem to show, I exported it from Houdini. It works in Cycles & Renderman.
https://www.deepfxworld.com/public_down ... penvdb.zip
							Animated OpenVDB Volumes
Re: Animated OpenVDB Volumes
Okay, thanks. I currently use v2.4 for continuity reasons, since the feature set ticks all my use cases. If this problem has been fixed for the latest release then I may upgrade to a newer release in the future.
I need a complete scene (.cfg, .scn, etc.), the VDB file alone doesn't tell me very much.Continuum wrote: Sat Aug 28, 2021 1:10 pm This file also doesn't seem to show, I exported it from Houdini. It works in Cycles & Renderman.
Anyway, the source of your problem is in how the VDB file is read and scaled for the densitygrid.
The OpenVDB file is scaled to match the densitygrid size: https://github.com/LuxCoreRender/LuxCor ... d.cpp#L114
and traslate to match the position, here: https://github.com/LuxCoreRender/LuxCor ... d.cpp#L153
This means the position and size information stored in the OpenVDB file are not used, the densitygrid will instead use its own position/scale information. In your case, you would like the opposite: to position/scale the densitygrid according the the VDB file.
It is is something it should be possible to add with a specific flag/option, I will check.
Okay thank you for looking into this. I wasn't sure about the scaling. I was implementing a OpenGl raycasting shader  and run into a similar issue since the vdb has to be a 3d texture, so went another direction.
I also discovered some older videos and noticed there was an offset bounding box option in Blender, but it is no longer available.
I think I am beginning to understand how this works. So I dived into the SDK instead, and I am beginning to get results within my application (I still can't get blender to animate imported vdb's though). But I am also having problems using vdb files generated in other apps. Getting closer though.
https://www.youtube.com/watch?v=SyP1BJJQwWA
