Noise behind a piece of glass
Re: Noise behind a piece of glass
Try to use periodic updates with less samples between cache rebuilding (I think the setting is "step samples" or so).
naruto123sdo
It solved the noise issue! Thanks!B.Y.O.B. wrote: Thu Jun 24, 2021 5:21 pm Try to use periodic updates with less samples between cache rebuilding (I think the setting is "step samples" or so).
