Film-only out-of-core rendering support (CUDA-only)
Re: Film-only out-of-core rendering support (CUDA-only)
In my short tests on Windows it seemed to work correctly.
B.Y.O.B. wrote: Sun Jun 20, 2021 4:51 pm
Sharlybg wrote: Sun Jun 20, 2021 4:04 pm Maybe i ask. When the user select this new option is going to be regular OOC+Film OOC ?
No, you can enable/disable both individually.
Simon, one includes the other "Full OoC" = "Film OoC + OtherStuff OoC": it should be probably a combo box, where you select if to have only the Film OoC or everything.
Odilkhan Yakubov
Post by Odilkhan Yakubov »
:) great sounds for me! But sorry guys, I have never used this option. Maybe someone teach me in which situations am I must to using this feature?
Thanks.
AndreasResch
Post by AndreasResch »
With FOOC enabled the rendering of a 7200px 4800px image finished after 2.5 hours. Without FFOC the rendering aborts with an OPENCL error. So that's a success. However above that resolution is't still a no-go and Blender just crashes without any message as soon as the GPU memory exceeds my available 6GB.
AndreasResch wrote: Mon Jun 21, 2021 9:28 am With FOOC enabled the rendering of a 7200px 4800px image finished after 2.5 hours. Without FFOC the rendering aborts with an OPENCL error. So that's a success. However above that resolution is't still a no-go and Blender just crashes without any message as soon as the GPU memory exceeds my available 6GB.
Your GPU may simple not support true OoC as explained in NVIDIA documentation: https://docs.nvidia.com/cuda/cuda-c-pro ... -migration
There may be also some limit if you are using Windows instead of Linux.
What GPU do you have ? Me and B.Y.O.B. have RTX GPUs.
Dade wrote: Sun Jun 20, 2021 10:47 pm Simon, one includes the other "Full OoC" = "Film OoC + OtherStuff OoC": it should be probably a combo box, where you select if to have only the Film OoC or everything.
Done.
AndreasResch
Dade wrote: Mon Jun 21, 2021 10:05 am
I can only compare it to Cycles at this point. And if Cycles seems to take advantage of that shared memory - with that very GPU and on Windows as well - I can't see, how the GPU should not be able to handle it. But of course I can't say what the task manager is actually displaying there and what happens behind the curtain. I have a GTX 980 Ti and a GTX 1060.
From what a little googling has show, Octane Render also seems to support OOC memory handling - probably on Windows as well.
[EDIT] Attached are the GPU stats of the same scene rendered in Cycles (at a higher resolution of 9600px in width). As you can see, there are 5.7GB of RAM used for the GPU which in total results in 11.3GB.
Cycles uses tile rendering, the option of this thread is for progressive rendering (i.e. you should use Cycles X).
AndreasResch
I don't see what tiled rendering has to to with the capability to use shared memory or not. And I can't use Cycles X at the moment as the GPU memory management is not properly implemented yet. It throws an error right away.
And I don't mind tiled path rendering. Once it works properly in Luxcore, I'm more than happy to use it.
AndreasResch wrote: Mon Jun 21, 2021 11:33 am I don't see what tiled rendering has to to with the capability to use shared memory or not.
One allocated a 7200x4800 while the other allocated a 64x64 film, I don't see how you can not see the difference.
